Ga door naar hoofdinhoud
Linksys WRT54G Motherboard Component Replacement
Wat je nodig hebt
  1. Linksys WRT54G Motherboard Component Replacement, Antennas: stap 1, afbeelding 1 van 1
    • Unfold the antennas straight away from the device.
  2. Linksys WRT54G Motherboard Component Replacement: stap 2, afbeelding 1 van 3 Linksys WRT54G Motherboard Component Replacement: stap 2, afbeelding 2 van 3 Linksys WRT54G Motherboard Component Replacement: stap 2, afbeelding 3 van 3
    • Remove the black caps from the antennas by pulling them away from the device.
  3. Linksys WRT54G Motherboard Component Replacement: stap 3, afbeelding 1 van 3 Linksys WRT54G Motherboard Component Replacement: stap 3, afbeelding 2 van 3 Linksys WRT54G Motherboard Component Replacement: stap 3, afbeelding 3 van 3
    • Unscrew each of the antennas from the wireless device.
  4. Linksys WRT54G Motherboard Component Replacement, Casing: stap 4, afbeelding 1 van 2 Linksys WRT54G Motherboard Component Replacement, Casing: stap 4, afbeelding 2 van 2
    • Using a bit of force, remove the blue plastic case.
  5. Linksys WRT54G Motherboard Component Replacement, Motherboard: stap 5, afbeelding 1 van 2 Linksys WRT54G Motherboard Component Replacement, Motherboard: stap 5, afbeelding 2 van 2
    • To remove the black casing that surrounds the green motherboard, slide the top half of the casing backwards. It only moves a very short distance.
    • Pull the top piece upwards and away from the bottom to remove.
  6. Linksys WRT54G Motherboard Component Replacement: stap 6, afbeelding 1 van 2 Linksys WRT54G Motherboard Component Replacement: stap 6, afbeelding 2 van 2
    • Locate the 2 M2.5x6mm screws that attach the motherboard to the back case.
    • Remove the two screws from the motherboard as indicated with the Phillips head screwdriver.
  7. Linksys WRT54G Motherboard Component Replacement: stap 7, afbeelding 1 van 1
    • Once screws have been removed, slide the motherboard in the direction of its LED lights.
    • Lift motherboard up and away from the black lower casing.
  8. Linksys WRT54G Motherboard Component Replacement, Motherboard Component: stap 8, afbeelding 1 van 1
    • Obtain a desoldering wick (Desoldering Braid). Plug in soldering iron and allow to heat. For soldering information, refer to the iFixit soldering guide (Hoe moet je (de-)solderen?).
    • Make sure that the soldering iron is not resting on top of anything that would be damaged by the heat.
  9. Linksys WRT54G Motherboard Component Replacement: stap 9, afbeelding 1 van 2 Linksys WRT54G Motherboard Component Replacement: stap 9, afbeelding 2 van 2
    • Identify the functional component which will be removed.
    • Turn the board over so that the pins holding the component in are exposed.
  10. Linksys WRT54G Motherboard Component Replacement: stap 10, afbeelding 1 van 1
    • Desolder each pin using the iFixit Soldering Guide (Hoe moet je (de-)solderen?). Gently remove functional component for replacement.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Nicole C
102 Reputatie
1 Handleiding geschreven
Cal Poly, Team 17-7, Regan Fall 2011 Lid van Cal Poly, Team 17-7, Regan Fall 2011
CPSU-REGAN-F11S17G7
4 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 14
Altijd: 3,861
