Inleiding
The scanner unit allows users to scan copies.
Wat je nodig hebt
Hold the button down with the flat end away from the printer. When you hear a click, the duplex unit can be removed from the printer.
Locate the two screw holes that connect the two cylindrical extensions from the top portion of the scanner unit to the printer.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
