Ga door naar hoofdinhoud
LexiBook Tablet One Speaker Replacement
Wat je nodig hebt
  1. LexiBook Tablet One Speaker Replacement, Speaker: stap 1, afbeelding 1 van 3 LexiBook Tablet One Speaker Replacement, Speaker: stap 1, afbeelding 2 van 3 LexiBook Tablet One Speaker Replacement, Speaker: stap 1, afbeelding 3 van 3
    • Insert the blue plastic opening tool where the case has a seam. Move side to side until you hear a clip pop. Move around the edge of the case until all clips are separated. The clips are 1.5 in. apart within the case.
    Vraag FixBot
    Voeg opmerking toe
  2. LexiBook Tablet One Speaker Replacement: stap 2, afbeelding 1 van 2 LexiBook Tablet One Speaker Replacement: stap 2, afbeelding 2 van 2
    • After successfully separating the casing insert a plastic spudger between the case and the speaker. Carefully pry the speaker out. Once the speaker is removed set the back casing aside.
    Vraag FixBot
    Voeg opmerking toe
  3. LexiBook Tablet One Speaker Replacement: stap 3, afbeelding 1 van 1
    • Using a soldering gun, apply heat where the speaker wires meet the motherboard. Heat the solder around both the black and red wires until they easily slide away.
    • Be careful not to heat the motherboard too long so to avoid damaging other components. Also, care to avoid liquefying the solder on any near by components.
    • How to Solder is IFixIt's official guide to use a soldering gun.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Jordan
650 Reputatie
4 handleidingen geschreven
Colorado Springs, Team 2-5, Panko Spring 2015 Lid van Colorado Springs, Team 2-5, Panko Spring 2015
UCCS-PANKO-S15S2G5
3 Leden
10 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 24
Altijd: 412
