Inleiding
Your Levoit Core 300-RAC's power board distributes power safely from a wall outlet to the fan and control board. If your device's fan stops spinning or it simply won't power on, then your power board may have failed. This guide will walk you through replacing this critical part.
Before you begin the repair, take a look at the Levoit Core 300-RAC Troubleshooting page. Once you've determined it is the power board that needs to be replaced, make sure to power off the device and unplug it from the outlet before you begin.
Wat je nodig hebt
Use a Phillips #2 screwdriver to remove the four screws that secure the gray lid towards the base of the device.
