Ga door naar hoofdinhoud
Lenovo Yoga Tab 3 8 LCD Replacement
Wat je nodig hebt
Video overzicht
  1. Lenovo Yoga Tab 3 8 LCD Replacement, Back Cover: stap 1, afbeelding 1 van 3 Lenovo Yoga Tab 3 8 LCD Replacement, Back Cover: stap 1, afbeelding 2 van 3 Lenovo Yoga Tab 3 8 LCD Replacement, Back Cover: stap 1, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • Open the kickstand by pressing the release button in the center.
    • Remove the identification sticker with a pair of tweezers to allow access to the two 2mm screws underneath.
  2. Lenovo Yoga Tab 3 8 LCD Replacement: stap 2, afbeelding 1 van 1
    • Remove the three 2mm screws under the kickstand with a PH00 screwdriver.
    • The third 2mm screw to the right may have an S sticker covering it which you can scrape off.
    PH000 is the correct size.
    Thomas Cacaj - Antwoord
  3. Lenovo Yoga Tab 3 8 LCD Replacement: stap 3, afbeelding 1 van 3 Lenovo Yoga Tab 3 8 LCD Replacement: stap 3, afbeelding 2 van 3 Lenovo Yoga Tab 3 8 LCD Replacement: stap 3, afbeelding 3 van 3
    • Starting along the edge opposite of the hinge, insert a plastic opening tool between the screen and the backing to begin separating the small clips holding the backing on.
    • Work along the edge and then up the sides, separating the clips with the plastic opening tool.
    • There is adhesive underneath the slot for the SD card so you will need to slowly apply some force to break the adhesive.
    • As the back is separated from the device, be careful to not lose the power button. It may come loose and fall out.
    this step is not clear. Where are the clips ? The screen looks inset. How to insert the tool ?
    Chiruvolu Sivachander - Antwoord
  4. Lenovo Yoga Tab 3 8 LCD Replacement, LCD: stap 4, afbeelding 1 van 3 Lenovo Yoga Tab 3 8 LCD Replacement, LCD: stap 4, afbeelding 2 van 3 Lenovo Yoga Tab 3 8 LCD Replacement, LCD: stap 4, afbeelding 3 van 3
    • With the device oriented screen side down and hinge opposite of you, locate the LCD connection on the motherboard. It is the small copper and white connector to the left of the kickstand lock. Disengage the lock on the connector by flipping it up with a pair of tweezers. Use the tweezers to then pull the wire out of the connector.
    • On the right edge of the motherboard, locate the large brown and black LCD connection. Disengage the lock and pull the wire out of the connector with the tweezers.
  5. Lenovo Yoga Tab 3 8 LCD Replacement: stap 5, afbeelding 1 van 3 Lenovo Yoga Tab 3 8 LCD Replacement: stap 5, afbeelding 2 van 3 Lenovo Yoga Tab 3 8 LCD Replacement: stap 5, afbeelding 3 van 3
    • Heat the iOpener and lay it flat along an edge of the LCD for 2-5 minutes to loosen the screen adhesive.
    • Insert a plastic opening tool under the LCD and gently pry it away from the adhesive. Place opening picks as you go along all four edges to keep the adhesive from sticking again.
    • Do not insert the opening picks too far or it might damage the LCD
    • Do not force the LCD while prying or it may shatter. Reheat and reapply your iOpener if the adhesive does not separate easily.
  6. Lenovo Yoga Tab 3 8 LCD Replacement: stap 6, afbeelding 1 van 1
    • Lift the LCD out with your fingers, being careful that the wires do not catch.
    Hi thereā€¦
    Tq for your guide i had changed the screen.
    But after that i hv another problem, the tablet itself easier to get hot and the battery drain faster. may i kno what i had miss?
    Stanlley Sim Phone - Antwoord
Conclusie
7 andere personen hebben deze handleiding voltooid.
Nicklaus Krems
1.067 Reputatie
8 handleidingen geschreven
USF Tampa, Team S16-G2, Eyestone Fall 2017 Lid van USF Tampa, Team S16-G2, Eyestone Fall 2017
USFT-EYESTONE-F17S16G2
4 Leden
16 handleidingen geschreven
3Gids Commentaar
Do I need to add glue when reinstalling the lcd?
cousineau915 - Antwoord
Yes but very little and I prefer to use araldite Or fevibond
Game Master Pro -
While repairing I forgot to keep the black ribbon located at the right corner of the motherboard what should I do
Priji Sabu - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 47
Altijd: 9,301
