Ga door naar hoofdinhoud
Lenovo Yoga 900-13ISK Battery Replacement
Wat je nodig hebt
  1. Lenovo Yoga 900-13ISK Battery Replacement, Back Cover: stap 1, afbeelding 1 van 2 Lenovo Yoga 900-13ISK Battery Replacement, Back Cover: stap 1, afbeelding 2 van 2
    • Using a T5 Torx screwdriver, remove the ten 5.5 mm screws from the back case of the laptop.
  2. Lenovo Yoga 900-13ISK Battery Replacement: stap 2, afbeelding 1 van 3 Lenovo Yoga 900-13ISK Battery Replacement: stap 2, afbeelding 2 van 3 Lenovo Yoga 900-13ISK Battery Replacement: stap 2, afbeelding 3 van 3
    • Use a spudger to pry open the back case at the hinges of the laptop.
    • There are plastic clips around the perimeter of the case holding down the back cover. These will need to be popped off as the cover is removed.
    • Use your fingers to completely pop off the back cover.
  3. Lenovo Yoga 900-13ISK Battery Replacement, Battery: stap 3, afbeelding 1 van 3 Lenovo Yoga 900-13ISK Battery Replacement, Battery: stap 3, afbeelding 2 van 3 Lenovo Yoga 900-13ISK Battery Replacement, Battery: stap 3, afbeelding 3 van 3
    • Remove the five 3.6 mm screws from the battery with a Phillips #00 screwdriver.
  4. Lenovo Yoga 900-13ISK Battery Replacement: stap 4, afbeelding 1 van 3 Lenovo Yoga 900-13ISK Battery Replacement: stap 4, afbeelding 2 van 3 Lenovo Yoga 900-13ISK Battery Replacement: stap 4, afbeelding 3 van 3
    • Grab the bottom corners of the battery and gently pull the battery until the cable disconnects from the connector on the motherboard.
    • While reassembling, use a plastic spudger to push the battery cable into the connector on the underside of the motherboard. This will be easier to do before the screws are replaced.
Conclusie
For optimal performance, after completing this guide, calibrate your newly installed battery.
Één andere persoon heeft deze handleiding voltooid.
Austin Blakely
19.536 Reputatie
53 handleidingen geschreven
iFixit Lid van iFixit
Staff
135 Leden
17.198 handleidingen geschreven
Één opmerking
Phillips 00 will not fit the 5 screws in my computer!
Elaine Gelb - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 57
Altijd: 2,674
