Ga door naar hoofdinhoud
Lenovo Thinkpad T450 Internal Battery Replacement
Wat je nodig hebt
  1. Lenovo Thinkpad T450 Internal Battery Replacement, External Battery: stap 1, afbeelding 1 van 3 Lenovo Thinkpad T450 Internal Battery Replacement, External Battery: stap 1, afbeelding 2 van 3 Lenovo Thinkpad T450 Internal Battery Replacement, External Battery: stap 1, afbeelding 3 van 3
    • Using your hands, slide the two locking tabs away from each other to release the battery.
    • Slide the battery up and out of the device.
  2. Lenovo Thinkpad T450 Internal Battery Replacement, Back Cover: stap 2, afbeelding 1 van 1
    • Using the JIS #00 screwdriver, unscrew seven screws from the back cover.
    • These screws are not removable and will remain in the back cover.
    • Use the JIS #00 screwdriver to remove the single 2.8 mm screw from the back cover.
  3. Lenovo Thinkpad T450 Internal Battery Replacement: stap 3, afbeelding 1 van 3 Lenovo Thinkpad T450 Internal Battery Replacement: stap 3, afbeelding 2 van 3 Lenovo Thinkpad T450 Internal Battery Replacement: stap 3, afbeelding 3 van 3
    • Insert a plastic opening tool into the edges of the laptop and work your way around the edges to pry off the back cover from the device.
    • Remove the back cover from the device.
  4. Lenovo Thinkpad T450 Internal Battery Replacement, Internal Battery: stap 4, afbeelding 1 van 2 Lenovo Thinkpad T450 Internal Battery Replacement, Internal Battery: stap 4, afbeelding 2 van 2
    • Using the JIS #00 screwdriver, remove the three 2.8 mm screws.
  5. Lenovo Thinkpad T450 Internal Battery Replacement: stap 5, afbeelding 1 van 2 Lenovo Thinkpad T450 Internal Battery Replacement: stap 5, afbeelding 2 van 2
    • Disconnect the battery cable from the motherboard using the plastic opening tool.
  6. Lenovo Thinkpad T450 Internal Battery Replacement: stap 6, afbeelding 1 van 1
    • Lift up and remove the battery from the device.
Conclusie
For optimal performance, after completing this guide, calibrate your newly installed battery.
Justin Ogihara
27.236 Reputatie
52 handleidingen geschreven
EDU Team Lid van EDU Team
Staff
7 Leden
637 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 7
Afgelopen 7 dagen: 34
Afgelopen 30 dagen: 162
Altijd: 4,398
