Ga door naar hoofdinhoud
Lenovo ThinkPad X390 Battery Replacement
Wat je nodig hebt
  1. Lenovo ThinkPad X390 Battery Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Turn off and power down the laptop before proceeding with the guide.
    • Flip your laptop over and place on a flat surface so you can access the screws on the base cover.
    • Using a Phillips #0 screwdriver, unscrew the five screws on the base cover.
    • The screws are not removable.
  2. Lenovo ThinkPad X390 Battery Replacement: stap 2, afbeelding 1 van 2 Lenovo ThinkPad X390 Battery Replacement: stap 2, afbeelding 2 van 2
    • Remove the base cover by inserting a plastic opening tool in between the cover and the rest of the laptop.
    • Once the tool is inserted, slide the tool along the edges of the case and push down on the opening tool to detach the case.
    • You may need to move the tool to different locations to fully release the back cover.
  3. Lenovo ThinkPad X390 Battery Replacement, Battery: stap 3, afbeelding 1 van 2 Lenovo ThinkPad X390 Battery Replacement, Battery: stap 3, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Using tweezers, unplug the battery from the laptops motherboard by pulling on the cable that attaches it.
  4. Lenovo ThinkPad X390 Battery Replacement: stap 4, afbeelding 1 van 2 Lenovo ThinkPad X390 Battery Replacement: stap 4, afbeelding 2 van 2
    • Using a Phillips #0 screwdriver, remove the four 5.2 mm screws holding the battery in place.
  5. Lenovo ThinkPad X390 Battery Replacement: stap 5, afbeelding 1 van 2 Lenovo ThinkPad X390 Battery Replacement: stap 5, afbeelding 2 van 2
    • Using your hands, remove the battery from the laptop.
Conclusie
For optimal performance, after completing this guide, calibrate your newly installed battery.
Curtis Kubacka
261 Reputatie
2 handleidingen geschreven
Clemson, Team 5-1, Hunter Fall 2021 Lid van Clemson, Team 5-1, Hunter Fall 2021
CLEM-HUNTER-F21S5G1
5 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 8
Afgelopen 7 dagen: 42
Afgelopen 30 dagen: 267
Altijd: 4,572
