Ga door naar hoofdinhoud
Lenovo ThinkPad T560 Keyboard Replacement
Wat je nodig hebt
  1. Lenovo ThinkPad T560 Keyboard Replacement, Keyboard: stap 1, afbeelding 1 van 3 Lenovo ThinkPad T560 Keyboard Replacement, Keyboard: stap 1, afbeelding 2 van 3 Lenovo ThinkPad T560 Keyboard Replacement, Keyboard: stap 1, afbeelding 3 van 3
    • Before you begin this guide, make sure to disable the internal battery, power down the device and disconnect from any external power sources.
    • Using the spudger, slide the keyboard up towards the display at the notches created for this purpose.
    Vraag FixBot
    Voeg opmerking toe
  2. Lenovo ThinkPad T560 Keyboard Replacement: stap 2, afbeelding 1 van 1
    • Using the Phillips #0 screwdriver, remove the six 3.5 mm screws that secure the keyboard to the laptop.
    Vraag FixBot
    Voeg opmerking toe
  3. Lenovo ThinkPad T560 Keyboard Replacement: stap 3, afbeelding 1 van 2 Lenovo ThinkPad T560 Keyboard Replacement: stap 3, afbeelding 2 van 2
    • Using the spudger, push the keyboard toward the display and then slide it back out of the connector at top of the keyboard to remove.
    • Don't pull on the keyboard as it is attached by two ZIF connectors underneath.
    • Flip the keyboard over to expose the keyboard's connections to the motherboard and touchpad.
    Vraag FixBot
    Voeg opmerking toe
  4. Lenovo ThinkPad T560 Keyboard Replacement: stap 4, afbeelding 1 van 2 Lenovo ThinkPad T560 Keyboard Replacement: stap 4, afbeelding 2 van 2
    • Using the spudger, open the latches securing the keyboard's connections to the motherboard and touchpad.
    • Remove the keyboard.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Jackson Reynolds
517 Reputatie
5 handleidingen geschreven
Clemson, Team 1-3, Hunter Spring 2022 Lid van Clemson, Team 1-3, Hunter Spring 2022
CLEM-HUNTER-S22S1G3
5 Leden
12 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 19
Afgelopen 30 dagen: 57
Altijd: 3,118
