Ga door naar hoofdinhoud
Lenovo ThinkPad T480s SSD Replacement
Wat je nodig hebt
  1. Lenovo ThinkPad T480s SSD Replacement, SSD: stap 1, afbeelding 1 van 3 Lenovo ThinkPad T480s SSD Replacement, SSD: stap 1, afbeelding 2 van 3 Lenovo ThinkPad T480s SSD Replacement, SSD: stap 1, afbeelding 3 van 3
    • Turn off the laptop and disconnect the power cord.
    • Turn the laptop back on and press the F1 button repeatedly to access the BIOS menu.
    • The BIOS is built in software for the computer. For this fix we will just need to use it to disconnect the battery.
    • The battery needs to be disconnected to avoid electro-static discharge. This is static electricity from your body that can damage electronics.
  2. Lenovo ThinkPad T480s SSD Replacement: stap 2, afbeelding 1 van 3 Lenovo ThinkPad T480s SSD Replacement: stap 2, afbeelding 2 van 3 Lenovo ThinkPad T480s SSD Replacement: stap 2, afbeelding 3 van 3
    • Once in the BIOS menu, press the arrow keys to select the desired options from the menu.
    • First, press the right arrow to select the Config menu.
    • Next, press the down arrow to select the Power option.
    • Lastly, press the down arrow to select the Disable Built-in Battery option. The laptop will then shut off.
  3. Lenovo ThinkPad T480s SSD Replacement: stap 3, afbeelding 1 van 2 Lenovo ThinkPad T480s SSD Replacement: stap 3, afbeelding 2 van 2
    • Flip the laptop upside down to access the back panel.
    • Loosen the six screws using the Phillips #0 screwdriver.
    • These screws are not removable.
  4. Lenovo ThinkPad T480s SSD Replacement: stap 4, afbeelding 1 van 3 Lenovo ThinkPad T480s SSD Replacement: stap 4, afbeelding 2 van 3 Lenovo ThinkPad T480s SSD Replacement: stap 4, afbeelding 3 van 3
    • Use an opening tool to gently pry the back panel away from the laptop.
    • Start from either side of the laptop. Work your way around until all sides are loose.
  5. Lenovo ThinkPad T480s SSD Replacement: stap 5, afbeelding 1 van 3 Lenovo ThinkPad T480s SSD Replacement: stap 5, afbeelding 2 van 3 Lenovo ThinkPad T480s SSD Replacement: stap 5, afbeelding 3 van 3
    • Use a Phillips #0 screwdriver to remove the screw attached to the SSD.
    • The SSD will pop out at 45 degree angle. Gently tug the SSD and it should come out smoothly.
  6. Lenovo ThinkPad T480s SSD Replacement: stap 6, afbeelding 1 van 3 Lenovo ThinkPad T480s SSD Replacement: stap 6, afbeelding 2 van 3 Lenovo ThinkPad T480s SSD Replacement: stap 6, afbeelding 3 van 3
    • Line up the replacement SSD according to the pin pattern of the slot.
    • Gently push the SSD into the slot. Ensure it is fully inserted.
    • Use the screw from the previous step to secure the SSD to the motherboard.
  7. Lenovo ThinkPad T480s SSD Replacement: stap 7, afbeelding 1 van 3 Lenovo ThinkPad T480s SSD Replacement: stap 7, afbeelding 2 van 3 Lenovo ThinkPad T480s SSD Replacement: stap 7, afbeelding 3 van 3
    • Align the back panel with the four hinges towards the battery side. Ensure the hinges are put in first when laying the back panel down.
    • Gently press on all sides so that it clicks into place. Then tighten the six screws with the Phillips #0 screwdriver to secure the back panel.
  8. Lenovo ThinkPad T480s SSD Replacement: stap 8, afbeelding 1 van 2 Lenovo ThinkPad T480s SSD Replacement: stap 8, afbeelding 2 van 2
    • Flip over the laptop, reconnect the power, cord and turn on the laptop.
    • The built-in battery will be reconnected automatically by sensing the power cord.
Conclusie
With the replacement of the SSD complete the computer needs Windows 10 to run. A new version of Windows 10 can be installed or data can be recovered through the backup.
8 andere personen hebben deze handleiding voltooid.
Alejandro Carranza
355 Reputatie
1 Handleiding geschreven
3Gids Commentaar
Great tutorial -- thanks for posting, I recommend cloning the disk via a thunderbolt enclosure prior to installing, if you buy a Samsung SSD, you can use the SSD clone software for this they provide . Then install the drive -- with any luck it should boot right up.
Jason D'Rion - Antwoord
I think you mean SSD enclosure (specifically for NVMe SSDs).
Tai Lam -
As a response to the other commenter:
I used Foxclone to clone the disk. It's an ISO that you burn to a USB, then boot it up, and from there clone the drive.
tobi - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 19
Afgelopen 7 dagen: 91
Afgelopen 30 dagen: 437
Altijd: 26,475
