Ga door naar hoofdinhoud
Lenovo ThinkPad T470 RAM Replacement
Wat je nodig hebt
  1. Lenovo ThinkPad T470 RAM Replacement, External Battery: stap 1, afbeelding 1 van 3 Lenovo ThinkPad T470 RAM Replacement, External Battery: stap 1, afbeelding 2 van 3 Lenovo ThinkPad T470 RAM Replacement, External Battery: stap 1, afbeelding 3 van 3
    • Before you begin this guide, make sure to disable the internal battery, power down your device, and disconnect from any external power sources.
    • Place the laptop so that the bottom is facing upwards.
    • Slide the latch on the left side of the battery to the left until it clicks in place.
  2. Lenovo ThinkPad T470 RAM Replacement: stap 2, afbeelding 1 van 3 Lenovo ThinkPad T470 RAM Replacement: stap 2, afbeelding 2 van 3 Lenovo ThinkPad T470 RAM Replacement: stap 2, afbeelding 3 van 3
    • Slide the latch on the right side of the battery to the right and hold it in place with your thumb.
    • Use your other hand to slide the battery towards the back of the laptop.
    • Lift the battery up and away from the laptop.
  3. Lenovo ThinkPad T470 RAM Replacement, Bottom Cover: stap 3, afbeelding 1 van 2 Lenovo ThinkPad T470 RAM Replacement, Bottom Cover: stap 3, afbeelding 2 van 2
    • Use a Phillips #1 screwdriver to loosen the six captive screws on the bottom cover of the laptop.
  4. Lenovo ThinkPad T470 RAM Replacement: stap 4, afbeelding 1 van 3 Lenovo ThinkPad T470 RAM Replacement: stap 4, afbeelding 2 van 3 Lenovo ThinkPad T470 RAM Replacement: stap 4, afbeelding 3 van 3
    • Use your hands to pull up on the back cover and release the plastic clips starting on the bottom side of the battery compartment.
    • Potential for device damage: Be sure to detach the plastic clips in this area first. You risk cracking the bottom cover if you attempt to detach it from around the edges of the laptop first.
    • Use your hands to pull up on the right side of the bottom cover to release the plastic clips.
    • Use your hands to pull up on the left side of the bottom cover to release the plastic clips.
  5. Lenovo ThinkPad T470 RAM Replacement: stap 5, afbeelding 1 van 1
    • Remove the bottom cover from the laptop.
    • Disconnect the battery from the board before continuing.
  6. Lenovo ThinkPad T470 RAM Replacement, RAM: stap 6, afbeelding 1 van 3 Lenovo ThinkPad T470 RAM Replacement, RAM: stap 6, afbeelding 2 van 3 Lenovo ThinkPad T470 RAM Replacement, RAM: stap 6, afbeelding 3 van 3
    • Use your fingers to flip the black flap covering the top stick of RAM down.
  7. Lenovo ThinkPad T470 RAM Replacement: stap 7, afbeelding 1 van 2 Lenovo ThinkPad T470 RAM Replacement: stap 7, afbeelding 2 van 2
    • Use your fingers to push the metal clips on either end of the RAM outwards.
    • The RAM will pop up by a few millimeters.
  8. Lenovo ThinkPad T470 RAM Replacement: stap 8, afbeelding 1 van 2 Lenovo ThinkPad T470 RAM Replacement: stap 8, afbeelding 2 van 2
    • Use your fingers to lift the RAM out of its socket and away from the laptop to remove it.
  9. Lenovo ThinkPad T470 RAM Replacement: stap 9, afbeelding 1 van 2 Lenovo ThinkPad T470 RAM Replacement: stap 9, afbeelding 2 van 2
    • Use your fingers to flip the black flap covering the bottom stick of RAM up.
    • Use your thumbs to push the metal clips on either end of the RAM outwards.
  10. Lenovo ThinkPad T470 RAM Replacement: stap 10, afbeelding 1 van 2 Lenovo ThinkPad T470 RAM Replacement: stap 10, afbeelding 2 van 2
    • The RAM will pop up slightly.
  11. Lenovo ThinkPad T470 RAM Replacement: stap 11, afbeelding 1 van 2 Lenovo ThinkPad T470 RAM Replacement: stap 11, afbeelding 2 van 2
Conclusie
3 andere personen hebben deze handleiding voltooid.
Kristen Gismondi
92.267 Reputatie
241 handleidingen geschreven
iFixit Lid van iFixit
Staff
118 Leden
19.532 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 51
Afgelopen 30 dagen: 267
Altijd: 11,415
