Ga door naar hoofdinhoud
Lenovo ThinkPad T470 Keyboard Replacement
Wat je nodig hebt
  1. Lenovo ThinkPad T470 Keyboard Replacement, External Battery: stap 1, afbeelding 1 van 3 Lenovo ThinkPad T470 Keyboard Replacement, External Battery: stap 1, afbeelding 2 van 3 Lenovo ThinkPad T470 Keyboard Replacement, External Battery: stap 1, afbeelding 3 van 3
    • Before you begin this guide, make sure to disable the internal battery, power down your device, and disconnect from any external power sources.
    • Place the laptop so that the bottom is facing upwards.
    • Slide the latch on the left side of the battery to the left until it clicks in place.
  2. Lenovo ThinkPad T470 Keyboard Replacement: stap 2, afbeelding 1 van 3 Lenovo ThinkPad T470 Keyboard Replacement: stap 2, afbeelding 2 van 3 Lenovo ThinkPad T470 Keyboard Replacement: stap 2, afbeelding 3 van 3
    • Slide the latch on the right side of the battery to the right and hold it in place with your thumb.
    • Use your other hand to slide the battery towards the back of the laptop.
    • Lift the battery up and away from the laptop.
  3. Lenovo ThinkPad T470 Keyboard Replacement, Keyboard: stap 3, afbeelding 1 van 2 Lenovo ThinkPad T470 Keyboard Replacement, Keyboard: stap 3, afbeelding 2 van 2
    • Loosen the two captive Phillips #1 screws on the back cover of the laptop.
  4. Lenovo ThinkPad T470 Keyboard Replacement: stap 4, afbeelding 1 van 2 Lenovo ThinkPad T470 Keyboard Replacement: stap 4, afbeelding 2 van 2
    • Place the laptop so that the top is facing upwards.
    • Open the lid of the laptop.
  5. Lenovo ThinkPad T470 Keyboard Replacement: stap 5, afbeelding 1 van 2 Lenovo ThinkPad T470 Keyboard Replacement: stap 5, afbeelding 2 van 2
    • Place your fingers on the bottom edge of the keyboard.
    • Apply a small amount of pressure to push the keyboard towards the screen.
  6. Lenovo ThinkPad T470 Keyboard Replacement: stap 6, afbeelding 1 van 3 Lenovo ThinkPad T470 Keyboard Replacement: stap 6, afbeelding 2 van 3 Lenovo ThinkPad T470 Keyboard Replacement: stap 6, afbeelding 3 van 3
    • Grab the bottom edge of the keyboard with your hands, and flip the keyboard upside-down, so it rests on the bottom of the laptop.
    • Potential for device damage: The keyboard is still attached to the rest of the laptop, so be gentle when flipping it over.
  7. Lenovo ThinkPad T470 Keyboard Replacement: stap 7, afbeelding 1 van 2 Lenovo ThinkPad T470 Keyboard Replacement: stap 7, afbeelding 2 van 2
    • Use the flat end of a spudger to flip up the locking flaps securing each of the two ribbon cables.
  8. Lenovo ThinkPad T470 Keyboard Replacement: stap 8, afbeelding 1 van 2 Lenovo ThinkPad T470 Keyboard Replacement: stap 8, afbeelding 2 van 2
    • Use your hands to lift the keyboard up and away from the laptop.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Kristen Gismondi
92.493 Reputatie
241 handleidingen geschreven
iFixit Lid van iFixit
Staff
118 Leden
19.604 handleidingen geschreven
Één opmerking
Absolut BRAVO
Mega tolle kostenlose mit "lLiebe" hergestellte Anleitungen !
Bin 1979 auf dem 6502 mit dabei.
Dieses Dokument ist eine weitere
Bestätigung, das der Griff zu LENOVO' Produkte stehts die richtige Wahl war
wen es auch wie jetzt nur die suche nach den Befestigunsschrauben der Tastatur war.
Danke für die schöne Daus komp. Anleitung
S.Kopp
aus Luzern-CH
Stefan Kopp - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 42
Afgelopen 30 dagen: 170
Altijd: 7,349
