Ga door naar hoofdinhoud
Lenovo ThinkPad T470 Fan and Heat Sink Replacement
Wat je nodig hebt
  1. Lenovo ThinkPad T470 Fan and Heat Sink Replacement, External Battery: stap 1, afbeelding 1 van 3 Lenovo ThinkPad T470 Fan and Heat Sink Replacement, External Battery: stap 1, afbeelding 2 van 3 Lenovo ThinkPad T470 Fan and Heat Sink Replacement, External Battery: stap 1, afbeelding 3 van 3
    • Before you begin this guide, make sure to disable the internal battery, power down your device, and disconnect from any external power sources.
    • Place the laptop so that the bottom is facing upwards.
    • Slide the latch on the left side of the battery to the left until it clicks in place.
  2. Lenovo ThinkPad T470 Fan and Heat Sink Replacement: stap 2, afbeelding 1 van 3 Lenovo ThinkPad T470 Fan and Heat Sink Replacement: stap 2, afbeelding 2 van 3 Lenovo ThinkPad T470 Fan and Heat Sink Replacement: stap 2, afbeelding 3 van 3
    • Slide the latch on the right side of the battery to the right and hold it in place with your thumb.
    • Use your other hand to slide the battery towards the back of the laptop.
    • Lift the battery up and away from the laptop.
  3. Lenovo ThinkPad T470 Fan and Heat Sink Replacement, Bottom Cover: stap 3, afbeelding 1 van 2 Lenovo ThinkPad T470 Fan and Heat Sink Replacement, Bottom Cover: stap 3, afbeelding 2 van 2
    • Use a Phillips #1 screwdriver to loosen the six captive screws on the bottom cover of the laptop.
  4. Lenovo ThinkPad T470 Fan and Heat Sink Replacement: stap 4, afbeelding 1 van 3 Lenovo ThinkPad T470 Fan and Heat Sink Replacement: stap 4, afbeelding 2 van 3 Lenovo ThinkPad T470 Fan and Heat Sink Replacement: stap 4, afbeelding 3 van 3
    • Use your hands to pull up on the back cover and release the plastic clips starting on the bottom side of the battery compartment.
    • Potential for device damage: Be sure to detach the plastic clips in this area first. You risk cracking the bottom cover if you attempt to detach it from around the edges of the laptop first.
    • Use your hands to pull up on the right side of the bottom cover to release the plastic clips.
    • Use your hands to pull up on the left side of the bottom cover to release the plastic clips.
  5. Lenovo ThinkPad T470 Fan and Heat Sink Replacement: stap 5, afbeelding 1 van 1
    • Remove the bottom cover from the laptop.
    • Disconnect the battery from the board before continuing.
  6. Lenovo ThinkPad T470 Fan and Heat Sink Replacement, Fan and Heat Sink: stap 6, afbeelding 1 van 2 Lenovo ThinkPad T470 Fan and Heat Sink Replacement, Fan and Heat Sink: stap 6, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Use a pair of blunt nose tweezers to pull the white fan connector out of its socket on the motherboard.
  7. Lenovo ThinkPad T470 Fan and Heat Sink Replacement: stap 7, afbeelding 1 van 2 Lenovo ThinkPad T470 Fan and Heat Sink Replacement: stap 7, afbeelding 2 van 2
    • Use a Phillips #1 screwdriver to loosen the first pair of captive screws on the fan and heat sink assembly in a crosswise pattern.
    • Use a Phillips #1 screwdriver to loosen the second pair of captive screws on the fan and heat sink assembly in a crosswise pattern.
    • Secure the screws using the same cross-pattern when reassembling the heatsink and fan.
  8. Lenovo ThinkPad T470 Fan and Heat Sink Replacement: stap 8, afbeelding 1 van 2 Lenovo ThinkPad T470 Fan and Heat Sink Replacement: stap 8, afbeelding 2 van 2
    • Use your hand to pull the fan and heat sink assembly up and away from the laptop.
    • Clean the thermal paste from the heatsink and CPU and reapply fresh paste before reassembling.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Kristen Gismondi
92.267 Reputatie
241 handleidingen geschreven
iFixit Lid van iFixit
Staff
118 Leden
19.532 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 19
Afgelopen 30 dagen: 60
Altijd: 3,014
