Inleiding
Use this guide to replace the USB board cable in a Lenovo ThinkPad T460 laptop.
The USB board cable connects the USB port to the motherboard. If your laptop does not recognize any peripherals plugged into the USB port, the USB board cable may be loose or faulty.
Make sure to disable the internal battery, power down your device, and disconnect from any external power sources before you begin.
Wat je nodig hebt
Place the laptop so that the bottom is facing upwards.
Slide the latch on the left side of the battery to the left until it clicks in place.
Loosen the eight captive screws in the bottom cover using a Phillips #1 screwdriver.
Insert the flat end of a spudger in between the bottom cover and the rest of the laptop, starting in the lower left corner.
Pry the lower left corner of the bottom cover up by a few millimeters.
Slide the spudger along the bottom of the laptop to release the clips until you reach the lower right corner.
