Ga door naar hoofdinhoud
Lenovo ThinkPad T460 Coin Cell Battery Replacement
Wat je nodig hebt
  1. Lenovo ThinkPad T460 Coin Cell Battery Replacement, External Battery: stap 1, afbeelding 1 van 3 Lenovo ThinkPad T460 Coin Cell Battery Replacement, External Battery: stap 1, afbeelding 2 van 3 Lenovo ThinkPad T460 Coin Cell Battery Replacement, External Battery: stap 1, afbeelding 3 van 3
    • Before you begin this guide, make sure to disable the internal battery, power down your device, and disconnect from any external power sources.
    • Place the laptop so that the bottom is facing upwards.
    • Slide the latch on the left side of the battery to the left until it clicks in place.
  2. Lenovo ThinkPad T460 Coin Cell Battery Replacement: stap 2, afbeelding 1 van 3 Lenovo ThinkPad T460 Coin Cell Battery Replacement: stap 2, afbeelding 2 van 3 Lenovo ThinkPad T460 Coin Cell Battery Replacement: stap 2, afbeelding 3 van 3
    • Slide the latch on the right side of the battery to the right and hold it in place with your thumb.
    • Use your other hand to slide the battery towards the back of the laptop.
    • Lift the battery up and away from the laptop.
  3. Lenovo ThinkPad T460 Coin Cell Battery Replacement, Bottom Cover: stap 3, afbeelding 1 van 2 Lenovo ThinkPad T460 Coin Cell Battery Replacement, Bottom Cover: stap 3, afbeelding 2 van 2
    • Loosen the eight captive screws in the bottom cover using a Phillips #1 screwdriver.
  4. Lenovo ThinkPad T460 Coin Cell Battery Replacement: stap 4, afbeelding 1 van 3 Lenovo ThinkPad T460 Coin Cell Battery Replacement: stap 4, afbeelding 2 van 3 Lenovo ThinkPad T460 Coin Cell Battery Replacement: stap 4, afbeelding 3 van 3
    • Insert the flat end of a spudger in between the bottom cover and the rest of the laptop, starting in the lower left corner.
    • Pry the lower left corner of the bottom cover up by a few millimeters.
    • Slide the spudger along the bottom of the laptop to release the clips until you reach the lower right corner.
    • You may hear some snapping noises as the clips are released.
  5. Lenovo ThinkPad T460 Coin Cell Battery Replacement: stap 5, afbeelding 1 van 2 Lenovo ThinkPad T460 Coin Cell Battery Replacement: stap 5, afbeelding 2 van 2
    • Slide the spudger along the right and top sides of the bottom cover to release the clips.
    • Potential for device damage: If the clips do not release easily, check to ensure that the captive screws are fully loosened. Forcing the clips to detach can crack the bottom cover.
  6. Lenovo ThinkPad T460 Coin Cell Battery Replacement: stap 6, afbeelding 1 van 2 Lenovo ThinkPad T460 Coin Cell Battery Replacement: stap 6, afbeelding 2 van 2
    • Use the spudger to pry the upper left corner up by a few millimeters.
    • Pry up the sections of the bottom cover with printed logos of the ports.
    • Potential for device damage: Prying inside the ports themselves can damage your laptop. Be sure to only pry up on the sections of the cover that extend past the ports.
  7. Lenovo ThinkPad T460 Coin Cell Battery Replacement: stap 7, afbeelding 1 van 2 Lenovo ThinkPad T460 Coin Cell Battery Replacement: stap 7, afbeelding 2 van 2
    • Use the spudger to pry up the bottom cover in the lower portion of the external battery compartment by a few millimeters.
  8. Lenovo ThinkPad T460 Coin Cell Battery Replacement: stap 8, afbeelding 1 van 3 Lenovo ThinkPad T460 Coin Cell Battery Replacement: stap 8, afbeelding 2 van 3 Lenovo ThinkPad T460 Coin Cell Battery Replacement: stap 8, afbeelding 3 van 3
    • Use both hands to lift the bottom cover up and away from the laptop.
  9. Lenovo ThinkPad T460 Coin Cell Battery Replacement, Coin Cell Battery: stap 9, afbeelding 1 van 2 Lenovo ThinkPad T460 Coin Cell Battery Replacement, Coin Cell Battery: stap 9, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Use a pair of blunt nose tweezers to pull the white connector out of its socket.
    • This connector may be difficult to remove. You can use a pair of tweezers to gently rock the connector back and forth until it is free from the socket.
  10. Lenovo ThinkPad T460 Coin Cell Battery Replacement: stap 10, afbeelding 1 van 2 Lenovo ThinkPad T460 Coin Cell Battery Replacement: stap 10, afbeelding 2 van 2
    • Use your fingers to pull the red and black bundled wire from its slot.
  11. Lenovo ThinkPad T460 Coin Cell Battery Replacement: stap 11, afbeelding 1 van 2 Lenovo ThinkPad T460 Coin Cell Battery Replacement: stap 11, afbeelding 2 van 2
    • Pry the battery up using the flat end of a spudger.
    • You may need to loosen the adhesive underneath the battery with the spudger before the battery can be removed.
Conclusie
Kristen Gismondi
92.618 Reputatie
241 handleidingen geschreven
iFixit Lid van iFixit
Staff
118 Leden
19.643 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 38
Altijd: 2,639
