Inleiding
Use this guide to replace the charging port in your Lenovo ThinkPad T460 laptop.
The charging port (also called a DC-in cable) provides power to the laptop in the form of direct current (DC). If your battery fails to charge, or you need to wiggle the charging cable around to maintain a charge, the charging port may be failing.
Make sure to disable the internal battery, power down your device, and disconnect from any external power sources before you begin.
Wat je nodig hebt
Place the laptop so that the bottom is facing upwards.
Slide the latch on the left side of the battery to the left until it clicks in place.
Loosen the eight captive screws in the bottom cover using a Phillips #1 screwdriver.
Insert the flat end of a spudger in between the bottom cover and the rest of the laptop, starting in the lower left corner.
Pry the lower left corner of the bottom cover up by a few millimeters.
Slide the spudger along the bottom of the laptop to release the clips until you reach the lower right corner.
Remove two 4.7 mm screws from the hinge in the upper right-hand corner using a Phillips #1 screwdriver.
Één andere persoon heeft deze handleiding voltooid.
