Ga door naar hoofdinhoud
Lenovo ThinkPad T16 Gen 3 WWAN Card Replacement
Wat je nodig hebt
  1. Lenovo ThinkPad T16 Gen 3 WWAN Card Replacement, Prepare your laptop for disassembly: stap 1, afbeelding 1 van 3 Lenovo ThinkPad T16 Gen 3 WWAN Card Replacement, Prepare your laptop for disassembly: stap 1, afbeelding 2 van 3 Lenovo ThinkPad T16 Gen 3 WWAN Card Replacement, Prepare your laptop for disassembly: stap 1, afbeelding 3 van 3
    • For your safety, discharge your battery below 25% before disassembling your laptop. A charged battery may catch fire if damaged. If your battery is swollen, take appropriate precautions.
    • Completely shut down your laptop (don't just put it in sleep mode) and disconnect all cables.
    • Flip the laptop upside-down, and rotate it so the screen hinge faces towards you.
  2. Lenovo ThinkPad T16 Gen 3 WWAN Card Replacement, Loosen the base cover screws: stap 2, afbeelding 1 van 2 Lenovo ThinkPad T16 Gen 3 WWAN Card Replacement, Loosen the base cover screws: stap 2, afbeelding 2 van 2
    • Use a Phillips screwdriver to fully loosen the seven captive screws securing the base cover.
  3. Lenovo ThinkPad T16 Gen 3 WWAN Card Replacement, Pry up the base cover: stap 3, afbeelding 1 van 3 Lenovo ThinkPad T16 Gen 3 WWAN Card Replacement, Pry up the base cover: stap 3, afbeelding 2 van 3 Lenovo ThinkPad T16 Gen 3 WWAN Card Replacement, Pry up the base cover: stap 3, afbeelding 3 van 3
    • Insert your fingernail or an opening pick into the gap between the base cover and keyboard deck, next to one of the screen hinges.
    • Pry up the base cover until the clips unfasten.
  4. Lenovo ThinkPad T16 Gen 3 WWAN Card Replacement, Remove the base cover: stap 4, afbeelding 1 van 2 Lenovo ThinkPad T16 Gen 3 WWAN Card Replacement, Remove the base cover: stap 4, afbeelding 2 van 2
    • Grasp the base cover along the screen hinge edge and lift slowly to unfasten the remaining clips.
    • Lift and remove the base cover.
    • During reassembly, lay the base cover into the frame, inserting it into the tabs along the battery edge. Press down firmly around the perimeter to reengage all the clips.
  5. Lenovo ThinkPad T16 Gen 3 WWAN Card Replacement, Loosen the battery screws: stap 5, afbeelding 1 van 2 Lenovo ThinkPad T16 Gen 3 WWAN Card Replacement, Loosen the battery screws: stap 5, afbeelding 2 van 2
    • Because of the battery connector's design, the only way to disconnect the battery is by physically removing it.
    • Use a Phillips screwdriver to fully loosen the two captive screws securing the battery connector.
  6. Lenovo ThinkPad T16 Gen 3 WWAN Card Replacement, Remove the battery: stap 6, afbeelding 1 van 3 Lenovo ThinkPad T16 Gen 3 WWAN Card Replacement, Remove the battery: stap 6, afbeelding 2 van 3 Lenovo ThinkPad T16 Gen 3 WWAN Card Replacement, Remove the battery: stap 6, afbeelding 3 van 3
    • Lift the edge of the battery with the connector to disconnect it.
    • You may feel a little resistance from the battery connector as it disconnects—that's normal.
    • Remove the battery
    • During reassembly:
    • Slide the plastic tabs on the long edge of the battery into their recesses in the frame.
    • Lower the battery into place so the connector goes over its socket.
  7. Lenovo ThinkPad T16 Gen 3 WWAN Card Replacement, Disconnect the antennas: stap 7, afbeelding 1 van 3 Lenovo ThinkPad T16 Gen 3 WWAN Card Replacement, Disconnect the antennas: stap 7, afbeelding 2 van 3 Lenovo ThinkPad T16 Gen 3 WWAN Card Replacement, Disconnect the antennas: stap 7, afbeelding 3 van 3
    • Insert one arm of your angled tweezers under the metal neck of one of the antenna coaxial connectors on the WWAN card and lift straight up to disconnect it.
  8. Lenovo ThinkPad T16 Gen 3 WWAN Card Replacement: stap 8, afbeelding 1 van 3 Lenovo ThinkPad T16 Gen 3 WWAN Card Replacement: stap 8, afbeelding 2 van 3 Lenovo ThinkPad T16 Gen 3 WWAN Card Replacement: stap 8, afbeelding 3 van 3
    • Repeat the process to disconnect the remaining antenna cables from the WWAN card.
    • During reassembly, use tweezers to hold each connector in place over its socket and gently press down with your finger or a spudger—the connector should "snap" into place. If you're having trouble, reposition the head instead of using more force.
  9. Lenovo ThinkPad T16 Gen 3 WWAN Card Replacement, Remove the WWAN card screw: stap 9, afbeelding 1 van 1
    • Use a Phillips screwdriver to remove the 4 mm‑long screw securing the WWAN card to the motherboard.
  10. Lenovo ThinkPad T16 Gen 3 WWAN Card Replacement, Disconnect the WWAN card: stap 10, afbeelding 1 van 3 Lenovo ThinkPad T16 Gen 3 WWAN Card Replacement, Disconnect the WWAN card: stap 10, afbeelding 2 van 3 Lenovo ThinkPad T16 Gen 3 WWAN Card Replacement, Disconnect the WWAN card: stap 10, afbeelding 3 van 3
    • Use your fingernail to lift up the WWAN card enough to grasp it with your fingers.
    • Pull the WWAN card away from its socket.
  11. Lenovo ThinkPad T16 Gen 3 WWAN Card Replacement, Remove the WWAN card: stap 11, afbeelding 1 van 1
    • Remove the WWAN card from your laptop.
    • Check the condition of the thermal pad under the SSD and replace it if damaged. It is 20 x 30 mm and 0.5 mm thick. The Lenovo part number is 5M20Z56333. If the pad remained intact but is stuck to the bottom of the old WWAN card, carefully transfer it to its spot on the board in between the WWAN card connector and its nearest screw hole.
Conclusie
Compare your new replacement part to the original part—you may need to transfer remaining components or remove thermal pad backings from the new part before you install it.
Nick Schultz
19.174 Reputatie
113 handleidingen geschreven
iFixit Lid van iFixit
Staff
118 Leden
19.545 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 58
Altijd: 503
