Ga door naar hoofdinhoud
Lenovo ThinkPad T16 Gen 3 Fan and Heatsink Assembly Replacement
Wat je nodig hebt
  1. Lenovo ThinkPad T16 Gen 3 Fan and Heatsink Assembly Replacement, Prepare your laptop for disassembly: stap 1, afbeelding 1 van 3 Lenovo ThinkPad T16 Gen 3 Fan and Heatsink Assembly Replacement, Prepare your laptop for disassembly: stap 1, afbeelding 2 van 3 Lenovo ThinkPad T16 Gen 3 Fan and Heatsink Assembly Replacement, Prepare your laptop for disassembly: stap 1, afbeelding 3 van 3
    • For your safety, discharge your battery below 25% before disassembling your laptop. A charged battery may catch fire if damaged. If your battery is swollen, take appropriate precautions.
    • Completely shut down your laptop (don't just put it in sleep mode) and disconnect all cables.
    • Flip the laptop upside-down, and rotate it so the screen hinge faces towards you.
  2. Lenovo ThinkPad T16 Gen 3 Fan and Heatsink Assembly Replacement, Loosen the base cover screws: stap 2, afbeelding 1 van 2 Lenovo ThinkPad T16 Gen 3 Fan and Heatsink Assembly Replacement, Loosen the base cover screws: stap 2, afbeelding 2 van 2
    • Use a Phillips screwdriver to fully loosen the seven captive screws securing the base cover.
  3. Lenovo ThinkPad T16 Gen 3 Fan and Heatsink Assembly Replacement, Pry up the base cover: stap 3, afbeelding 1 van 3 Lenovo ThinkPad T16 Gen 3 Fan and Heatsink Assembly Replacement, Pry up the base cover: stap 3, afbeelding 2 van 3 Lenovo ThinkPad T16 Gen 3 Fan and Heatsink Assembly Replacement, Pry up the base cover: stap 3, afbeelding 3 van 3
    • Insert your fingernail or an opening pick into the gap between the base cover and keyboard deck, next to one of the screen hinges.
    • Pry up the base cover until the clips unfasten.
  4. Lenovo ThinkPad T16 Gen 3 Fan and Heatsink Assembly Replacement, Remove the base cover: stap 4, afbeelding 1 van 2 Lenovo ThinkPad T16 Gen 3 Fan and Heatsink Assembly Replacement, Remove the base cover: stap 4, afbeelding 2 van 2
    • Grasp the base cover along the screen hinge edge and lift slowly to unfasten the remaining clips.
    • Lift and remove the base cover.
    • During reassembly, lay the base cover into the frame, inserting it into the tabs along the battery edge. Press down firmly around the perimeter to reengage all the clips.
  5. Lenovo ThinkPad T16 Gen 3 Fan and Heatsink Assembly Replacement, Loosen the battery screws: stap 5, afbeelding 1 van 2 Lenovo ThinkPad T16 Gen 3 Fan and Heatsink Assembly Replacement, Loosen the battery screws: stap 5, afbeelding 2 van 2
    • Because of the battery connector's design, the only way to disconnect the battery is by physically removing it.
    • Use a Phillips screwdriver to fully loosen the two captive screws securing the battery connector.
  6. Lenovo ThinkPad T16 Gen 3 Fan and Heatsink Assembly Replacement, Remove the battery: stap 6, afbeelding 1 van 3 Lenovo ThinkPad T16 Gen 3 Fan and Heatsink Assembly Replacement, Remove the battery: stap 6, afbeelding 2 van 3 Lenovo ThinkPad T16 Gen 3 Fan and Heatsink Assembly Replacement, Remove the battery: stap 6, afbeelding 3 van 3
    • Lift the edge of the battery with the connector to disconnect it.
    • You may feel a little resistance from the battery connector as it disconnects—that's normal.
    • Remove the battery
    • During reassembly:
    • Slide the plastic tabs on the long edge of the battery into their recesses in the frame.
    • Lower the battery into place so the connector goes over its socket.
  7. Lenovo ThinkPad T16 Gen 3 Fan and Heatsink Assembly Replacement, Disconnect the camera cable: stap 7, afbeelding 1 van 2 Lenovo ThinkPad T16 Gen 3 Fan and Heatsink Assembly Replacement, Disconnect the camera cable: stap 7, afbeelding 2 van 2
    • Use a spudger to gently push under the metal buckle of the camera cable connector to unclip it
  8. Lenovo ThinkPad T16 Gen 3 Fan and Heatsink Assembly Replacement: stap 8, afbeelding 1 van 2 Lenovo ThinkPad T16 Gen 3 Fan and Heatsink Assembly Replacement: stap 8, afbeelding 2 van 2
    • Grab the buckle and cable together and gently pull the connector straight out of its socket.
  9. Lenovo ThinkPad T16 Gen 3 Fan and Heatsink Assembly Replacement, Free the camera cable: stap 9, afbeelding 1 van 3 Lenovo ThinkPad T16 Gen 3 Fan and Heatsink Assembly Replacement, Free the camera cable: stap 9, afbeelding 2 van 3 Lenovo ThinkPad T16 Gen 3 Fan and Heatsink Assembly Replacement, Free the camera cable: stap 9, afbeelding 3 van 3
    • Hold the buckle and cable together and guide the cable out of the clips holding it to the fan.
  10. Lenovo ThinkPad T16 Gen 3 Fan and Heatsink Assembly Replacement, Disconnect the fan: stap 10, afbeelding 1 van 3 Lenovo ThinkPad T16 Gen 3 Fan and Heatsink Assembly Replacement, Disconnect the fan: stap 10, afbeelding 2 van 3 Lenovo ThinkPad T16 Gen 3 Fan and Heatsink Assembly Replacement, Disconnect the fan: stap 10, afbeelding 3 van 3
    • Use the point of a spudger to push on alternating sides of the fan connector to "walk" it out of its socket until fully disconnected.
    • This connector has a small marking that shows which side of the connector should be facing up. To reconnect, align the connector and use a spudger or clean fingernail to push it fully into the socket.
  11. Lenovo ThinkPad T16 Gen 3 Fan and Heatsink Assembly Replacement, Loosen the fan and heatsink screws: stap 11, afbeelding 1 van 2 Lenovo ThinkPad T16 Gen 3 Fan and Heatsink Assembly Replacement, Loosen the fan and heatsink screws: stap 11, afbeelding 2 van 2
    • Use a Phillips screwdriver to fully loosen the five captive screws securing the fan and heatsink.
    • During reassembly, tighten the screws in an "X" pattern in the order labeled: bottom left, top right, bottom right, top left.
  12. Lenovo ThinkPad T16 Gen 3 Fan and Heatsink Assembly Replacement, Remove the fan and heatsink assembly: stap 12, afbeelding 1 van 3 Lenovo ThinkPad T16 Gen 3 Fan and Heatsink Assembly Replacement, Remove the fan and heatsink assembly: stap 12, afbeelding 2 van 3 Lenovo ThinkPad T16 Gen 3 Fan and Heatsink Assembly Replacement, Remove the fan and heatsink assembly: stap 12, afbeelding 3 van 3
    • Pick up the fan and heatsink assembly by its edges and remove it from the laptop.
    • You may feel a little resistance from the thermal paste and pads between the heatsink and the components on the motherboard—this is normal.
  13. Lenovo ThinkPad T16 Gen 3 Fan and Heatsink Assembly Replacement, Reassembly information: stap 13, afbeelding 1 van 2 Lenovo ThinkPad T16 Gen 3 Fan and Heatsink Assembly Replacement, Reassembly information: stap 13, afbeelding 2 van 2
    • Before installing a new heatsink, follow this guide to clean the CPU and reapply thermal paste.
    • If you're only reapplying thermal paste and not replacing the heatsink, clean the bottom of the heatsink as well.
Conclusie
Compare your new replacement part to the original part—you may need to transfer remaining components or remove thermal pad backings from the new part before you install it.
Nick Schultz
19.304 Reputatie
113 handleidingen geschreven
iFixit Lid van iFixit
Staff
118 Leden
19.648 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 18
Altijd: 209
