Inleiding
Use this guide to replace the lower case on your Lenovo ThinkPad T15 Gen 2.
Before you perform this repair, be sure to completely power off and unplug your laptop. Make sure the laptop is not in standby, sleep, or hibernation mode.
Wat je nodig hebt
Use a Phillips #1 screwdriver to loosen the eight captive screws securing the lower case.
Insert an opening pick between the lower case and the chassis on the front right edge.
Angle the pick down at about 30˚.
Slide the pick along the front edge to release the clips securing the lower case.
Insert an opening tool between the lower case and the chassis, just to the right of the USB port on the left edge.
Pry the opening case up to release the clip next to the USB port.
Take your e-waste to an R2 or e-stewards certified recycler.
Repair didn't go as planned? Try some basic troubleshooting, or ask our Lenovo ThinkPad T Series answers community for help.
