Ga door naar hoofdinhoud
Lenovo Legion 5 15ACH6H Left SSD Replacement
Wat je nodig hebt
  1. Lenovo Legion 5 15ACH6H Left SSD Replacement, Back cover removal: stap 1, afbeelding 1 van 2 Lenovo Legion 5 15ACH6H Left SSD Replacement, Back cover removal: stap 1, afbeelding 2 van 2
    • Use a Phillips screwdriver to remove the following ten screws securing the back cover to frame:
    • Six 12.5 mm PH1 screws
    • Four 4.7 mm PH1 screws
  2. Lenovo Legion 5 15ACH6H Left SSD Replacement, Release the front clips: stap 2, afbeelding 1 van 3 Lenovo Legion 5 15ACH6H Left SSD Replacement, Release the front clips: stap 2, afbeelding 2 van 3 Lenovo Legion 5 15ACH6H Left SSD Replacement, Release the front clips: stap 2, afbeelding 3 van 3
    • Insert the rounded edge of an opening pick between the back cover and the frame in the lower right corner.
  3. Lenovo Legion 5 15ACH6H Left SSD Replacement: stap 3, afbeelding 1 van 3 Lenovo Legion 5 15ACH6H Left SSD Replacement: stap 3, afbeelding 2 van 3 Lenovo Legion 5 15ACH6H Left SSD Replacement: stap 3, afbeelding 3 van 3
    • Angle the pick to about 30˚.
    • Slide the pick along the front edge to release the clips securing the back cover to the frame.
  4. Lenovo Legion 5 15ACH6H Left SSD Replacement, Release the left clips: stap 4, afbeelding 1 van 2 Lenovo Legion 5 15ACH6H Left SSD Replacement, Release the left clips: stap 4, afbeelding 2 van 2
    • Insert the edge of an opening pick between the back cover and the frame on the right edge.
    • Angle the pick to about 30˚ and slide down the left edge to release the clips.
  5. Lenovo Legion 5 15ACH6H Left SSD Replacement, Release the right clips: stap 5, afbeelding 1 van 2 Lenovo Legion 5 15ACH6H Left SSD Replacement, Release the right clips: stap 5, afbeelding 2 van 2
    • Repeat the same procedure on the left edge to release the clips.
  6. Lenovo Legion 5 15ACH6H Left SSD Replacement, Release the right vent clips: stap 6, afbeelding 1 van 3 Lenovo Legion 5 15ACH6H Left SSD Replacement, Release the right vent clips: stap 6, afbeelding 2 van 3 Lenovo Legion 5 15ACH6H Left SSD Replacement, Release the right vent clips: stap 6, afbeelding 3 van 3
    • Position the laptop vertically so you can easily access the plastic vents.
    • Slide the rounded edge of an opening pick between the frame and the plastic vents on the left side near the USB-C port.
    • Rotate the pick so that it is positioned on top of the plastic vents.
  7. Lenovo Legion 5 15ACH6H Left SSD Replacement: stap 7, afbeelding 1 van 2 Lenovo Legion 5 15ACH6H Left SSD Replacement: stap 7, afbeelding 2 van 2
    • Push the pick between the frame and plastic vents.
    • Slide the pick along the top edge of the plastic vents to release the clips.
  8. Lenovo Legion 5 15ACH6H Left SSD Replacement, Release the left vent clips: stap 8, afbeelding 1 van 3 Lenovo Legion 5 15ACH6H Left SSD Replacement, Release the left vent clips: stap 8, afbeelding 2 van 3 Lenovo Legion 5 15ACH6H Left SSD Replacement, Release the left vent clips: stap 8, afbeelding 3 van 3
    • Slide the opening pick between the frame and the plastic vents on the right side near the USB-A port.
  9. Lenovo Legion 5 15ACH6H Left SSD Replacement: stap 9, afbeelding 1 van 2 Lenovo Legion 5 15ACH6H Left SSD Replacement: stap 9, afbeelding 2 van 2
  10. Lenovo Legion 5 15ACH6H Left SSD Replacement, Remove the back cover: stap 10, afbeelding 1 van 3 Lenovo Legion 5 15ACH6H Left SSD Replacement, Remove the back cover: stap 10, afbeelding 2 van 3 Lenovo Legion 5 15ACH6H Left SSD Replacement, Remove the back cover: stap 10, afbeelding 3 van 3
    • Lift the back cover up and remove it from the chassis.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
  11. Lenovo Legion 5 15ACH6H Left SSD Replacement, Disconnect the battery: stap 11, afbeelding 1 van 3 Lenovo Legion 5 15ACH6H Left SSD Replacement, Disconnect the battery: stap 11, afbeelding 2 van 3 Lenovo Legion 5 15ACH6H Left SSD Replacement, Disconnect the battery: stap 11, afbeelding 3 van 3
    • Use the pointed end of a spudger to push each side of the battery connector to loosen it.
  12. Lenovo Legion 5 15ACH6H Left SSD Replacement: stap 12, afbeelding 1 van 2 Lenovo Legion 5 15ACH6H Left SSD Replacement: stap 12, afbeelding 2 van 2
    • Use the flat end of a spudger to push out and disconnect battery cable.
  13. Lenovo Legion 5 15ACH6H Left SSD Replacement, Left SSD removal: stap 13, afbeelding 1 van 2 Lenovo Legion 5 15ACH6H Left SSD Replacement, Left SSD removal: stap 13, afbeelding 2 van 2
    • Use a Phillips screwdriver to remove the three 5.1 mm PH00 screws securing the left SSD shield to the motherboard.
    • During reassembly, make sure the hole near the top screw aligns with the post on the motherboard.
  14. Lenovo Legion 5 15ACH6H Left SSD Replacement, Remove the SSD shield: stap 14, afbeelding 1 van 3 Lenovo Legion 5 15ACH6H Left SSD Replacement, Remove the SSD shield: stap 14, afbeelding 2 van 3 Lenovo Legion 5 15ACH6H Left SSD Replacement, Remove the SSD shield: stap 14, afbeelding 3 van 3
    • Grab the SSD shield and lift up to remove it.
  15. Lenovo Legion 5 15ACH6H Left SSD Replacement: stap 15, afbeelding 1 van 2 Lenovo Legion 5 15ACH6H Left SSD Replacement: stap 15, afbeelding 2 van 2
    • Use a Phillips screwdriver to remove the 2.7 mm PH1 screw securing the SSD to the motherboard.
    • The SSD will spring up to about 30˚ when the screw is removed.
  16. Lenovo Legion 5 15ACH6H Left SSD Replacement, Remove the left SSD: stap 16, afbeelding 1 van 3 Lenovo Legion 5 15ACH6H Left SSD Replacement, Remove the left SSD: stap 16, afbeelding 2 van 3 Lenovo Legion 5 15ACH6H Left SSD Replacement, Remove the left SSD: stap 16, afbeelding 3 van 3
    • Grip the edges of the SSD near the screw indent.
    • Gently pull to remove the SSD.
Conclusie
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Lenovo Legion answers community for help.
7 andere personen hebben deze handleiding voltooid.
Chayton Ritter
22.518 Reputatie
105 handleidingen geschreven
Guide Team Lid van Guide Team
Staff
9 Leden
11.421 handleidingen geschreven
Één opmerking
sorry guys, I'm new to all this and I don't understand, exactly the same heatsink on the right side of the laptop what is it, is this really the second connector for the m2 PCI 3.0 x 4 ssd connector.
Pls help me
Albert XYZ - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 15
Afgelopen 7 dagen: 81
Afgelopen 30 dagen: 334
Altijd: 13,174
