Inleiding
Use this guide to replace the hard drive, also known as a hard disk drive or HDD, in a Lenovo IdeaPad S145-14IWL.
Wat je nodig hebt
Use a Phillips #0 screwdriver to remove the ten screws that secure the lower case.
Insert an opening tool into the gap between the lower case and chassis.
Pry around the perimeter of the device until the lower case fully releases.
Remove the lower case.
Use angled tweezers to gently pull the battery connector directly out of its socket.
Use a Phillips #0 screwdriver to remove the screws securing the battery.
Lift the battery up and out of the chassis.
Flip up the black ZIF locking flap that secures the hard drive ribbon cable.
Disconnect the ribbon cable.
Use a Phillips screwdriver to remove the screws that secure the hard drive.
Remove the hard drive.
Repair didn’t go as planned? Try some basic troubleshooting.
