Ga door naar hoofdinhoud
Lenovo IdeaPad 120s-14IAP Battery Replacement
Wat je nodig hebt
  1. Lenovo IdeaPad 120s-14IAP Battery Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Be sure to power off and unplug your device before you begin your repair.
    • Orient the laptop so the top is laying flat on your work surface.
    • Remove ten 1.5mm Torx T5 screws from the back of the laptop.
  2. Lenovo IdeaPad 120s-14IAP Battery Replacement: stap 2, afbeelding 1 van 1
    • Insert the plastic opening tool or a Jimmy along the edge of the back cover and gently pry.
    • Run the tool all the way around the edge of the back cover and remove the back cover once it is no longer secure.
    • Remove the back cover.
  3. Lenovo IdeaPad 120s-14IAP Battery Replacement, Battery: stap 3, afbeelding 1 van 1
    • Remove five 1.5mm Phillips screws from the battery edges.
  4. Lenovo IdeaPad 120s-14IAP Battery Replacement: stap 4, afbeelding 1 van 1
    • Use your fingers or a spudger to unlock the wide ribbon cable's ZIF connector.
    • To unlock a ZIF connector, flip up the small, hinged locking flap.
    • Gently pull the connector from the battery side until it is fully detached from the daughterboard.
  5. Lenovo IdeaPad 120s-14IAP Battery Replacement: stap 5, afbeelding 1 van 1
    • Gently pull the power harness away from the daughterboard until the connector is detached.
    • Pull parallel to the board, not straight up.
  6. Lenovo IdeaPad 120s-14IAP Battery Replacement: stap 6, afbeelding 1 van 1
    • With the laptop oriented so that the long edge faces you and the battery is closest to you, carefully remove the battery by lifting on the longitudinal edge.
    • Pull the battery directly towards you and out from under the forward retaining strap.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
2 opmerkingen
Thank you for showing exactly how to remove the battery connections, thanks!
Erik Gunnar Gervin - Antwoord
Great guide. I may well need a new battery but would appreciate your comment. Battery shows charging but never gets above 0%
When I put a meter at the 2 red cables they show zero volts (even when computer on, and showing charging). Other wires are ~1.6v & 3.4v.
Could I have a faulty battery or something else?
Colin Kinsella - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 39
Altijd: 5,175
