Inleiding
Use this guide to test and replace the water dispensing switch on your LG LFX 25973 refrigerator.
The water dispensing switch triggers a solenoid valve in the refrigerator so that it dispenses chilled water through the dispenser.
If the switch fails, the refrigerator will either not dispense water or won't stop dispensing water.
The repair is moderately difficult. The removal of the dispensing unit is probably the most challenging step.
Wat je nodig hebt
Unplug your refrigerator before you begin your repair.
Condenser Fan Motor
Compressor Motor and Thermal Overload Device
Water Supply Valve Assembly
To remove the left door handle, first open the right door.
Use a 2 1/2 mm hex wrench to loosen the set screws in the top and bottom of the left door handle.
Right side clips
Top clips
Left side clips (Note, the dispenser is being held upside down for the photo, so the upper left side clips are at the bottom of the photo.)
Use a spudger to pry out the top edge of the dispenser assembly.
Once you've created a gap, use your fingertips to pull the edge downward.
Use additional spudgers to unfasten the clips securing the dispenser assembly to the refrigerator door.
Grasp the top edge of the dispenser assembly in the middle and pull outwards.
Continue prying and pulling around the perimeter of the assembly to release it.
Squeeze the two multiple wire connectors and pull them straight off to disconnect them from the display board.
Do not attempt to remove the four-wire connector from the board as it is not removable.
Use a Phillips screwdriver to remove the 11 mm‑long screw securing the white circuit board holder to the dispenser assembly.
Lift and remove the circuit board holder from the dispenser assembly.
Use a Phillips screwdriver to remove the two 12.8 mm‑long screws securing the clear switch bracket to the dispenser assembly.
Lift the clear switch bracket off the dispenser assembly.
Slide the water dispensing switch off of its pegs on the bracket.
Pull the yellow and pink connector straight off the water dispensing switch to disconnect it.
Touch one probe to each of the switch terminals at the same time.
If the switch does not operate as described above, replace it.
