Ga door naar hoofdinhoud
LG G3 Vigor Headphone Jack Replacement
Wat je nodig hebt
  1. LG G3 Vigor Headphone Jack Replacement, Rear Case: stap 1, afbeelding 1 van 1
    • Locate the notch on the bottom right of the phone.
  2. LG G3 Vigor Headphone Jack Replacement: stap 2, afbeelding 1 van 1
    • Gently pull the cover on the back of the phone off to locate the battery.
  3. LG G3 Vigor Headphone Jack Replacement, Battery: stap 3, afbeelding 1 van 1
    • Remove the battery by lifting from the slot at the bottom of the battery.
  4. LG G3 Vigor Headphone Jack Replacement, Midframe: stap 4, afbeelding 1 van 1
    • Remove the twelve Phillips #00 screws securing the midframe to the rest of the phone.
  5. LG G3 Vigor Headphone Jack Replacement: stap 5, afbeelding 1 van 3 LG G3 Vigor Headphone Jack Replacement: stap 5, afbeelding 2 van 3 LG G3 Vigor Headphone Jack Replacement: stap 5, afbeelding 3 van 3
    • Work a plastic opening tool around the perimeter of the phone to separate the midframe from the rest of the phone.
  6. LG G3 Vigor Headphone Jack Replacement, Rear Facing Camera: stap 6, afbeelding 1 van 1
    • Use the spudger to gently unplug the ribbon cable connected to the motherboard. Then remove the rear facing camera.
  7. LG G3 Vigor Headphone Jack Replacement, Front Facing Camera: stap 7, afbeelding 1 van 2 LG G3 Vigor Headphone Jack Replacement, Front Facing Camera: stap 7, afbeelding 2 van 2
    • Remove the front camera.
  8. LG G3 Vigor Headphone Jack Replacement, Motherboard: stap 8, afbeelding 1 van 1
    • Use the flat edge of a spudger to disconnect the motherboard ribbon connector.
  9. LG G3 Vigor Headphone Jack Replacement: stap 9, afbeelding 1 van 2 LG G3 Vigor Headphone Jack Replacement: stap 9, afbeelding 2 van 2
    • Use the pointed end of a spudger to push back the two motherboard retaining flaps.
    • The motherboard should now be able to be lifted out of the device.
  10. LG G3 Vigor Headphone Jack Replacement, Headphone Jack: stap 10, afbeelding 1 van 1
    • Remove the headphone jack by inserting the spudger into the jack and pulling it up and out.
Conclusie
Geoff Wacker
91.128 Reputatie
89 handleidingen geschreven
Één opmerking
Works also with D855. There are only a view differences, e.g. screws and a minimal different motherboarddesign.
flux - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 473
