Ga door naar hoofdinhoud
LG G3 Vigor Earpiece Speaker Replacement
Wat je nodig hebt
  1. LG G3 Vigor Earpiece Speaker Replacement, Rear Case: stap 1, afbeelding 1 van 1
    • Locate the notch on the bottom right of the phone.
  2. LG G3 Vigor Earpiece Speaker Replacement: stap 2, afbeelding 1 van 1
    • Gently pull the cover on the back of the phone off to locate the battery.
  3. LG G3 Vigor Earpiece Speaker Replacement, Battery: stap 3, afbeelding 1 van 1
    • Remove the battery by lifting from the slot at the bottom of the battery.
  4. LG G3 Vigor Earpiece Speaker Replacement, Midframe: stap 4, afbeelding 1 van 1
    • Remove the twelve Phillips #00 screws securing the midframe to the rest of the phone.
  5. LG G3 Vigor Earpiece Speaker Replacement: stap 5, afbeelding 1 van 3 LG G3 Vigor Earpiece Speaker Replacement: stap 5, afbeelding 2 van 3 LG G3 Vigor Earpiece Speaker Replacement: stap 5, afbeelding 3 van 3
    • Work a plastic opening tool around the perimeter of the phone to separate the midframe from the rest of the phone.
  6. LG G3 Vigor Earpiece Speaker Replacement, Rear Facing Camera: stap 6, afbeelding 1 van 1
    • Use the spudger to gently unplug the ribbon cable connected to the motherboard. Then remove the rear facing camera.
  7. LG G3 Vigor Earpiece Speaker Replacement, Front Facing Camera: stap 7, afbeelding 1 van 2 LG G3 Vigor Earpiece Speaker Replacement, Front Facing Camera: stap 7, afbeelding 2 van 2
    • Remove the front camera.
  8. LG G3 Vigor Earpiece Speaker Replacement, Motherboard: stap 8, afbeelding 1 van 1
    • Use the flat edge of a spudger to disconnect the motherboard ribbon connector.
  9. LG G3 Vigor Earpiece Speaker Replacement: stap 9, afbeelding 1 van 2 LG G3 Vigor Earpiece Speaker Replacement: stap 9, afbeelding 2 van 2
    • Use the pointed end of a spudger to push back the two motherboard retaining flaps.
    • The motherboard should now be able to be lifted out of the device.
  10. LG G3 Vigor Earpiece Speaker Replacement, Earpiece Speaker: stap 10, afbeelding 1 van 1
    • Remove the earpiece speaker with the metal spudger by prying it out.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Geoff Wacker
91.128 Reputatie
89 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 288
