Ga door naar hoofdinhoud
LG G3 Vigor Earpiece Speaker Replacement
Wat je nodig hebt
  1. LG G3 Vigor Earpiece Speaker Replacement, Rear Case: stap 1, afbeelding 1 van 1
    • Locate the notch on the bottom right of the phone.
  2. LG G3 Vigor Earpiece Speaker Replacement: stap 2, afbeelding 1 van 1
    • Gently pull the cover on the back of the phone off to locate the battery.
  3. LG G3 Vigor Earpiece Speaker Replacement, Battery: stap 3, afbeelding 1 van 1
    • Remove the battery by lifting from the slot at the bottom of the battery.
  4. LG G3 Vigor Earpiece Speaker Replacement, Midframe: stap 4, afbeelding 1 van 1
    • Remove the twelve Phillips #00 screws securing the midframe to the rest of the phone.
  5. LG G3 Vigor Earpiece Speaker Replacement: stap 5, afbeelding 1 van 3 LG G3 Vigor Earpiece Speaker Replacement: stap 5, afbeelding 2 van 3 LG G3 Vigor Earpiece Speaker Replacement: stap 5, afbeelding 3 van 3
    • Work a plastic opening tool around the perimeter of the phone to separate the midframe from the rest of the phone.
  6. LG G3 Vigor Earpiece Speaker Replacement, Rear Facing Camera: stap 6, afbeelding 1 van 1
    • Use the spudger to gently unplug the ribbon cable connected to the motherboard. Then remove the rear facing camera.
  7. LG G3 Vigor Earpiece Speaker Replacement, Front Facing Camera: stap 7, afbeelding 1 van 2 LG G3 Vigor Earpiece Speaker Replacement, Front Facing Camera: stap 7, afbeelding 2 van 2
    • Remove the front camera.
  8. LG G3 Vigor Earpiece Speaker Replacement, Motherboard: stap 8, afbeelding 1 van 1
    • Use the flat edge of a spudger to disconnect the motherboard ribbon connector.
  9. LG G3 Vigor Earpiece Speaker Replacement: stap 9, afbeelding 1 van 2 LG G3 Vigor Earpiece Speaker Replacement: stap 9, afbeelding 2 van 2
    • Use the pointed end of a spudger to push back the two motherboard retaining flaps.
    • The motherboard should now be able to be lifted out of the device.
  10. LG G3 Vigor Earpiece Speaker Replacement, Earpiece Speaker: stap 10, afbeelding 1 van 1
    • Remove the earpiece speaker with the metal spudger by prying it out.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Geoff Wacker
91.140 Reputatie
89 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 288
