Ga door naar hoofdinhoud
LG G3 Motherboard Replacement
Wat je nodig hebt
  1. LG G3 Motherboard Replacement, Back Cover: stap 1, afbeelding 1 van 2 LG G3 Motherboard Replacement, Back Cover: stap 1, afbeelding 2 van 2
    • Power off your phone before beginning disassembly.
    • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover.
    • Pry the back cover up to separate its plastic clips.
  2. LG G3 Motherboard Replacement: stap 2, afbeelding 1 van 2 LG G3 Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Lift the back cover to release the rest of the plastic clips and remove it.
    • In case you can't lift the back cover completely, slide your fingernail or your prying tool around the midframe to release the remaining clips.
    • To reinstall the back cover, press it firmly into place until you hear a snap from the plastic clips to form a seamless connection with the rear side of the phone.
  3. LG G3 Motherboard Replacement, Battery: stap 3, afbeelding 1 van 2 LG G3 Motherboard Replacement, Battery: stap 3, afbeelding 2 van 2
    • Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
  4. LG G3 Motherboard Replacement: stap 4, afbeelding 1 van 2 LG G3 Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Lift the battery out of its recess and remove it.
  5. LG G3 Motherboard Replacement, Loudspeaker: stap 5, afbeelding 1 van 1
    • Remove the four Phillips #00 screws (4 mm length).
  6. LG G3 Motherboard Replacement: stap 6, afbeelding 1 van 2 LG G3 Motherboard Replacement: stap 6, afbeelding 2 van 2
    • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover you used earlier to remove the back cover.
    • Pry up the plastic panel, including the loudspeaker, until you can get a good grip.
  7. LG G3 Motherboard Replacement: stap 7, afbeelding 1 van 3 LG G3 Motherboard Replacement: stap 7, afbeelding 2 van 3 LG G3 Motherboard Replacement: stap 7, afbeelding 3 van 3
    • Carefully remove the plastic panel including the loudspeaker by gently pulling it away from the phone assembly.
  8. LG G3 Motherboard Replacement, Motherboard Cover Assembly: stap 8, afbeelding 1 van 1
    • Remove the eight Phillips #00 screws (4 mm length).
  9. LG G3 Motherboard Replacement: stap 9, afbeelding 1 van 3 LG G3 Motherboard Replacement: stap 9, afbeelding 2 van 3 LG G3 Motherboard Replacement: stap 9, afbeelding 3 van 3
    • Insert an opening pick between the bottom right corner of the motherboard cover and the motherboard.
    • Pry up the motherboard cover to open the plastic clips which hold the cover in its place.
    • The clips can be a bit resistive. If you're having trouble prying up the motherboard cover, slightly rotate the opening pick sideways to make the process easier.
    • Work your way along the right edge.
  10. LG G3 Motherboard Replacement: stap 10, afbeelding 1 van 3 LG G3 Motherboard Replacement: stap 10, afbeelding 2 van 3 LG G3 Motherboard Replacement: stap 10, afbeelding 3 van 3
    • Carefully lift the right edge of the motherboard cover.
    • The remaining plastic clips should open during this process or can be unhinged easily by hand.
    • Remove the motherboard assembly.
  11. LG G3 Motherboard Replacement, Motherboard: stap 11, afbeelding 1 van 2 LG G3 Motherboard Replacement, Motherboard: stap 11, afbeelding 2 van 2
    • Use a spudger to pry up and disconnect the display flex cable.
  12. LG G3 Motherboard Replacement: stap 12, afbeelding 1 van 2 LG G3 Motherboard Replacement: stap 12, afbeelding 2 van 2
    • Use a spudger to pry up and disconnect the digitizer flex cable.
  13. LG G3 Motherboard Replacement: stap 13, afbeelding 1 van 2 LG G3 Motherboard Replacement: stap 13, afbeelding 2 van 2
    • Use a spudger to pry up and disconnect the rear camera flex cable.
  14. LG G3 Motherboard Replacement: stap 14, afbeelding 1 van 2 LG G3 Motherboard Replacement: stap 14, afbeelding 2 van 2
    • Use a spudger to pry up and disconnect the front camera flex cable.
  15. LG G3 Motherboard Replacement: stap 15, afbeelding 1 van 2 LG G3 Motherboard Replacement: stap 15, afbeelding 2 van 2
    • During these next few steps, make sure to avoid damaging the flex cables you disconnected.
    • Slide an opening pick under the bottom right corner of the motherboard and slowly pry it out of its recess by rotating the opening pick sideways.
  16. LG G3 Motherboard Replacement: stap 16, afbeelding 1 van 2 LG G3 Motherboard Replacement: stap 16, afbeelding 2 van 2
    • Slide the opening pick under the right edge of the motherboard where the SIM card slot is located and pry it up by rotating the opening pick sideways.
  17. LG G3 Motherboard Replacement: stap 17, afbeelding 1 van 2 LG G3 Motherboard Replacement: stap 17, afbeelding 2 van 2
    • Grab the top section of the motherboard and carefully lift it out of the phone.
Conclusie
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
4 andere personen hebben deze handleiding voltooid.
Dominik Schnabelrauch
230.827 Reputatie
682 handleidingen geschreven
iFixit Lid van iFixit
Staff
118 Leden
19.648 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 41
Altijd: 3,513
