Ga door naar hoofdinhoud
LG G3 Loudspeaker Replacement
Wat je nodig hebt
  1. LG G3 Loudspeaker Replacement, Back Cover: stap 1, afbeelding 1 van 2 LG G3 Loudspeaker Replacement, Back Cover: stap 1, afbeelding 2 van 2
    • Power off your phone before beginning disassembly.
    • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover.
    • Pry the back cover up to separate its plastic clips.
  2. LG G3 Loudspeaker Replacement: stap 2, afbeelding 1 van 2 LG G3 Loudspeaker Replacement: stap 2, afbeelding 2 van 2
    • Lift the back cover to release the rest of the plastic clips and remove it.
    • In case you can't lift the back cover completely, slide your fingernail or your prying tool around the midframe to release the remaining clips.
    • To reinstall the back cover, press it firmly into place until you hear a snap from the plastic clips to form a seamless connection with the rear side of the phone.
  3. LG G3 Loudspeaker Replacement, Battery: stap 3, afbeelding 1 van 2 LG G3 Loudspeaker Replacement, Battery: stap 3, afbeelding 2 van 2
    • Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
  4. LG G3 Loudspeaker Replacement: stap 4, afbeelding 1 van 2 LG G3 Loudspeaker Replacement: stap 4, afbeelding 2 van 2
    • Lift the battery out of its recess and remove it.
  5. LG G3 Loudspeaker Replacement, Loudspeaker: stap 5, afbeelding 1 van 1
    • Remove the four Phillips #00 screws (4 mm length).
  6. LG G3 Loudspeaker Replacement: stap 6, afbeelding 1 van 2 LG G3 Loudspeaker Replacement: stap 6, afbeelding 2 van 2
    • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover you used earlier to remove the back cover.
    • Pry up the plastic panel, including the loudspeaker, until you can get a good grip.
  7. LG G3 Loudspeaker Replacement: stap 7, afbeelding 1 van 3 LG G3 Loudspeaker Replacement: stap 7, afbeelding 2 van 3 LG G3 Loudspeaker Replacement: stap 7, afbeelding 3 van 3
    • Carefully remove the plastic panel including the loudspeaker by gently pulling it away from the phone assembly.
Conclusie
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
8 andere personen hebben deze handleiding voltooid.
Dominik Schnabelrauch
253.919 Reputatie
682 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 26
Altijd: 14,630
