Ga door naar hoofdinhoud
LG G3 Battery Replacement
Wat je nodig hebt
  1. LG G3 Battery Replacement, Back Cover: stap 1, afbeelding 1 van 2 LG G3 Battery Replacement, Back Cover: stap 1, afbeelding 2 van 2
    • Power off your phone before beginning disassembly.
    • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover.
    • Pry the back cover up to separate its plastic clips.
  2. LG G3 Battery Replacement: stap 2, afbeelding 1 van 2 LG G3 Battery Replacement: stap 2, afbeelding 2 van 2
    • Lift the back cover to release the rest of the plastic clips and remove it.
    • In case you can't lift the back cover completely, slide your fingernail or your prying tool around the midframe to release the remaining clips.
    • To reinstall the back cover, press it firmly into place until you hear a snap from the plastic clips to form a seamless connection with the rear side of the phone.
  3. LG G3 Battery Replacement, Battery: stap 3, afbeelding 1 van 2 LG G3 Battery Replacement, Battery: stap 3, afbeelding 2 van 2
    • Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
  4. LG G3 Battery Replacement: stap 4, afbeelding 1 van 2 LG G3 Battery Replacement: stap 4, afbeelding 2 van 2
    • Lift the battery out of its recess and remove it.
Conclusie
For optimal performance, calibrate your newly installed battery: Charge it to 100%, and keep charging it for at least two more hours. Then, use it until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
21 andere personen hebben deze handleiding voltooid.
Dominik Schnabelrauch
251.209 Reputatie
682 handleidingen geschreven
1Gids Commentaar
Thank you very much!
ItayDigital - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 83
Afgelopen 30 dagen: 142
Altijd: 18,351
