Ga door naar hoofdinhoud
LG G Watch Spring Bar Pin Replacement
Wat je nodig hebt
  1. LG G Watch Spring Bar Pin Replacement, Wristband: stap 1, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Spring bars attach the two halves of the wristband to the watch body. The spring bar has a shoulder on either end.
    • Be prepared to apply some pressure with your fingers to perform the following action.
    • First, slide the wristband down on the spring bar to expose the shoulder of the spring bar.
    • Grasp the exposed shoulder with the tweezers to perform the next step.
  2. LG G Watch Spring Bar Pin Replacement: stap 2, afbeelding 1 van 2 LG G Watch Spring Bar Pin Replacement: stap 2, afbeelding 2 van 2
    • This is a challenging step. Do it carefully to prevent the spring bar from flying out of the wristband.
    • Use the tweezer to depress the spring bar so that it collapses by a few millimeters and pops out of the hole that was holding it in place.
    • Now carefully pull the other end of the spring bar to detach the wristband from the watch face.
    • Repeat steps 1 and 2 for the other wristband.
  3. LG G Watch Spring Bar Pin Replacement, Spring Bar Pin: stap 3, afbeelding 1 van 1
    • Slide the spring bar pin out of the wristband.
    • Repeat this step for the other wristband.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Geoff Wacker
92.080 Reputatie
89 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 18
Altijd: 1,144
