Ga door naar hoofdinhoud
LG Front Load Washing Machine Rotor Replacement
Wat je nodig hebt
    1. LG Front Load Washing Machine Rotor Replacement, Safety Precautions: stap 1, afbeelding 1 van 2 LG Front Load Washing Machine Rotor Replacement, Safety Precautions: stap 1, afbeelding 2 van 2
      • Before you begin your repair, perform the following:
      • Turn off the main water supply
      • Unplug your washer
      • Disconnect all water connections at the rear of your washer
      Vraag FixBot
      Voeg opmerking toe
    1. LG Front Load Washing Machine Rotor Replacement, Unfasten the rear panel: stap 2, afbeelding 1 van 3 LG Front Load Washing Machine Rotor Replacement, Unfasten the rear panel: stap 2, afbeelding 2 van 3 LG Front Load Washing Machine Rotor Replacement, Unfasten the rear panel: stap 2, afbeelding 3 van 3
      • Remove the screw(s) securing the rear panel.
      Vraag FixBot
      Voeg opmerking toe
    2. LG Front Load Washing Machine Rotor Replacement, Remove the rear panel: stap 3, afbeelding 1 van 3 LG Front Load Washing Machine Rotor Replacement, Remove the rear panel: stap 3, afbeelding 2 van 3 LG Front Load Washing Machine Rotor Replacement, Remove the rear panel: stap 3, afbeelding 3 van 3
      • Unclip the rear panel from the chassis.
      Vraag FixBot
      Voeg opmerking toe
    3. LG Front Load Washing Machine Rotor Replacement: stap 4, afbeelding 1 van 1
      • Remove the rear panel.
      Vraag FixBot
      Voeg opmerking toe
    1. LG Front Load Washing Machine Rotor Replacement, Unfasten the rotor: stap 5, afbeelding 1 van 2 LG Front Load Washing Machine Rotor Replacement, Unfasten the rotor: stap 5, afbeelding 2 van 2
      • Use an impact driver to remove the 17 mm nut securing the rotor.
      • Alternatively, you can use a wrench and a hammer to loosen the nut.
      • To secure the rotor, you can insert a screwdriver, or a similar tool, between the rotor and the stator. Make sure to brace the tool against one of the screw bosses on the stator.
      Vraag FixBot
      Voeg opmerking toe
    2. LG Front Load Washing Machine Rotor Replacement, Remove the rotor: stap 6, afbeelding 1 van 2 LG Front Load Washing Machine Rotor Replacement, Remove the rotor: stap 6, afbeelding 2 van 2
      • The rotor is magnetically attracted to the stator.
      • Pull the rotor straight off the stator and drive shaft splines to remove it.
      • Wiggle the rotor as you pull to help disconnect it.
      • This may require significant force.
      • During reassembly, watch your fingers when aligning the rotor over the stator, as the rotor gets sucked in easily.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Repair didn’t go as planned? Ask our Answers community for help.
Bill Gilbert
40.207 Reputatie
261 handleidingen geschreven
iFixit Lid van iFixit
Staff
123 Leden
71.656 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 23
Afgelopen 30 dagen: 107
Altijd: 2,384
