Ga door naar hoofdinhoud
LG Front Load Washing Machine Door Latch Replacement
Wat je nodig hebt
    1. LG Front Load Washing Machine Door Latch Replacement, Safety Precautions: stap 1, afbeelding 1 van 2 LG Front Load Washing Machine Door Latch Replacement, Safety Precautions: stap 1, afbeelding 2 van 2
      • Before you begin your repair, perform the following:
      • Turn off the main water supply
      • Unplug your washer
      • Disconnect all water connections at the rear of your washer
      Vraag FixBot
      Voeg opmerking toe
    1. LG Front Load Washing Machine Door Latch Replacement, Open the door: stap 2, afbeelding 1 van 2 LG Front Load Washing Machine Door Latch Replacement, Open the door: stap 2, afbeelding 2 van 2
      • Open the front door completely.
      Vraag FixBot
      Voeg opmerking toe
    2. LG Front Load Washing Machine Door Latch Replacement, Remove the boot ring: stap 3, afbeelding 1 van 3 LG Front Load Washing Machine Door Latch Replacement, Remove the boot ring: stap 3, afbeelding 2 van 3 LG Front Load Washing Machine Door Latch Replacement, Remove the boot ring: stap 3, afbeelding 3 van 3
      • Use needle nose pliers to grip the spring end of the metal ring at the bottom of the rubber boot.
      • Pull the ring away from the chassis to separate it from the boot.
      Vraag FixBot
      Voeg opmerking toe
    3. LG Front Load Washing Machine Door Latch Replacement: stap 4, afbeelding 1 van 3 LG Front Load Washing Machine Door Latch Replacement: stap 4, afbeelding 2 van 3 LG Front Load Washing Machine Door Latch Replacement: stap 4, afbeelding 3 van 3
      • Use your hand to completely pull the ring off the boot.
      • During reassembly, perform the following:
      • Insert one end of the ring into its groove along the boot's perimeter.
      • Use pliers to slowly stretch the ring around the boot's perimeter until it's completely nested in its groove.
      • Be sure the spring is centered at the bottom of the boot when you reinstall it.
      • This procedure will take significant force.
      Vraag FixBot
      Voeg opmerking toe
    4. LG Front Load Washing Machine Door Latch Replacement, Disconnect the boot: stap 5, afbeelding 1 van 3 LG Front Load Washing Machine Door Latch Replacement, Disconnect the boot: stap 5, afbeelding 2 van 3 LG Front Load Washing Machine Door Latch Replacement, Disconnect the boot: stap 5, afbeelding 3 van 3
      • Use your fingers to pull the boot off its lip in the front panel.
      Vraag FixBot
      Voeg opmerking toe
    5. LG Front Load Washing Machine Door Latch Replacement: stap 6, afbeelding 1 van 3 LG Front Load Washing Machine Door Latch Replacement: stap 6, afbeelding 2 van 3 LG Front Load Washing Machine Door Latch Replacement: stap 6, afbeelding 3 van 3
      • Work your fingers around the boot's perimeter until it's completely separated from the panel.
      Vraag FixBot
      Voeg opmerking toe
    6. LG Front Load Washing Machine Door Latch Replacement: stap 7, afbeelding 1 van 2 LG Front Load Washing Machine Door Latch Replacement: stap 7, afbeelding 2 van 2
      • Use your hands to fold the boot into the drum.
      Vraag FixBot
      Voeg opmerking toe
    7. LG Front Load Washing Machine Door Latch Replacement, Unfasten the door latch: stap 8, afbeelding 1 van 1
      • Remove the screw(s) securing the door latch.
      Vraag FixBot
      Voeg opmerking toe
    8. LG Front Load Washing Machine Door Latch Replacement, Expose the door latch: stap 9, afbeelding 1 van 3 LG Front Load Washing Machine Door Latch Replacement, Expose the door latch: stap 9, afbeelding 2 van 3 LG Front Load Washing Machine Door Latch Replacement, Expose the door latch: stap 9, afbeelding 3 van 3
      • Reach between the boot and the chassis to grip the door latch.
      • Pull the door latch out of its slot in the chassis to expose it.
      • Don't try to fully remove the door latch yet. It's still connected to a cable harness.
      Vraag FixBot
      Voeg opmerking toe
    9. LG Front Load Washing Machine Door Latch Replacement, Remove the door latch: stap 10, afbeelding 1 van 2 LG Front Load Washing Machine Door Latch Replacement, Remove the door latch: stap 10, afbeelding 2 van 2
      • Disconnect the cable harness from the door latch.
      • Always grip cables by their connectors and not the wires themselves.
      • Remove the door latch.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Repair didn’t go as planned? Ask our Answers community for help.
4 andere personen hebben deze handleiding voltooid.
Bill Gilbert
40.207 Reputatie
261 handleidingen geschreven
iFixit Lid van iFixit
Staff
123 Leden
70.606 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 7
Afgelopen 7 dagen: 68
Afgelopen 30 dagen: 367
Altijd: 11,176
