Inleiding
This guide will help you replace the LCD screen on your LG CF360 phone. It is a lengthy process, but don't let the number of steps intimidate you! Follow along and you will have a brand-new LCD screen installed in about an hour.
Please note that you will need a soldering iron to complete the replacement. If you need help on soldering, take a look at iFixit's Soldering Guide before you start.
Wat je nodig hebt
On the back of the phone, place your thumb on the three raised bumps and slide the back cover upward.
Gereedschap gebruikt in deze stap:Tweezers$4.99
Remove the two screw covers at the top of phone with tweezers.
Use the plastic opening tool to gently lift the snapped-in motherboard from the front panel.
Take the front case and unscrew the four Phillips #000 (1mm) screws around the ribbon.
Use a plastic opening tool to carefully disconnect the silver L-shaped LCD screen ribbon.
