Inleiding
Use this guide to replace the Limit Switch that tells the Keurig that the K-Cup section is closed.
Wat je nodig hebt
Remove the switch by cuting the two connecting wires. Reconnect a replacement switch using this guide to join wires with solder, or using this guide to solder connections, or by using any other technique to connect wires.
Één andere persoon heeft deze handleiding voltooid.
