Inleiding
Before reading this guide, ensure you know how to strip wires and solder a connection. If not, please look at the following guides.
Stripping Wire: Draad strippen
Soldering:Hoe moet je (de-)solderen?
Wat je nodig hebt
Put one of the paired wires on one of the helping hand's clamp. Put the other pair of wires on the remaining clamp.
This technique will allow wires to be extended both electrically and structurally without the need of longer wires.
8 andere personen hebben deze handleiding voltooid.
Één opmerking
Perhaps I might recommend sliding the H.S. tubing on before soldering the joint in case the wires are connected on the other end to something else.
