Ga door naar hoofdinhoud
Jazz UltraTab C855 Motherboard Replacement
Wat je nodig hebt
  1. Jazz UltraTab C855 Motherboard Replacement, Back Cover: stap 1, afbeelding 1 van 1
    Vraag FixBot
    Voeg opmerking toe
  2. Jazz UltraTab C855 Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Pry the back case off using the blue Plastic Opening Tools. Work one along the seem until you can get your fingers under to pull it apart.
    Vraag FixBot
    Voeg opmerking toe
  3. Jazz UltraTab C855 Motherboard Replacement, Motherboard: stap 3, afbeelding 1 van 1
    • Remove the two pieces of tape securing the ribbon cables to the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  4. Jazz UltraTab C855 Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Remove the 3 screws at the top of the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  5. Jazz UltraTab C855 Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Using a plastic prying tool, lift open the latch that secures the ribbon cable next to the speaker.
    • Pull the ribbon cable out of its connector on the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  6. Jazz UltraTab C855 Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Use a plastic prying tool to disconnect the other ribbon cable from the motherboard. This cable belongs to the device's cameras.
    Vraag FixBot
    Voeg opmerking toe
  7. Jazz UltraTab C855 Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Disconnect the large ribbon cable from the motherboard. Do this by unlocking the tabs on each side of the connector.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
    Vraag FixBot
    Voeg opmerking toe
  8. Jazz UltraTab C855 Motherboard Replacement: stap 8, afbeelding 1 van 1
    • Snip the two sets of wires that are attached to the motherboard. Cut the wires as close to the board as possible. This will leave plenty of length to reattach the wires to the new board.
    • Skip this step if you are only removing the motherboard to replace the screen.
    • During reassembly, we recommend soldering or crimping the wires away from the motherboard contacts. You should avoid soldering directly to the motherboard unless absolutely necessary. To learn more about soldering, check out iFixit's Soldering Skills Guide
    Vraag FixBot
    Voeg opmerking toe
Conclusie
andres maynez
113 Reputatie
1 Handleiding geschreven
IUPUI, Team 1-3, Baechle Fall 2015 Lid van IUPUI, Team 1-3, Baechle Fall 2015
IUPUI-BAECHLE-F15S1G3
5 Leden
10 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 27
Altijd: 716
