Ga door naar hoofdinhoud
Jazz UltraTab C855 Battery Replacement
Wat je nodig hebt
    1. Jazz UltraTab C855 Battery Replacement, Back Cover: stap 1, afbeelding 1 van 1
      Vraag FixBot
      Voeg opmerking toe
    2. Jazz UltraTab C855 Battery Replacement: stap 2, afbeelding 1 van 1
      • Pry the back case off using the blue Plastic Opening Tools. Work one along the seem until you can get your fingers under to pull it apart.
      Vraag FixBot
      Voeg opmerking toe
    1. Jazz UltraTab C855 Battery Replacement, Battery: stap 3, afbeelding 1 van 1
      • Remove the yellow tape from the sides of the battery, and the surrounding components.
      Vraag FixBot
      Voeg opmerking toe
    2. Jazz UltraTab C855 Battery Replacement: stap 4, afbeelding 1 van 1
      • Cut the pos(+) and neg (-) wires that connect the battery to the device using wire cutters.
      • Cut the wires towards the middle. During installation of your new battery these wires will be stripped back and soldered or crimped to reattach.
      Vraag FixBot
      Voeg opmerking toe
    3. Jazz UltraTab C855 Battery Replacement: stap 5, afbeelding 1 van 1
      • Using a plastic opening tool or spudger, slowly pry the battery away from the board.
      • The battery is secured to the device with adhesive.
      • Metal spudgers can puncture an unprotected battery, potentially causing a fire. When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
      Vraag FixBot
      Voeg opmerking toe
    4. Jazz UltraTab C855 Battery Replacement: stap 6, afbeelding 1 van 1
      • Use a two sided adhesive to secure the new battery in place.
      • Solder or crimp the wires back together to reattach to the motherboard.
      • Replace any yellow tape that you removed at the beginning to secure the wires back in place.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Cory Hodge
201 Reputatie
2 handleidingen geschreven
IUPUI, Team 1-3, Baechle Fall 2015 Lid van IUPUI, Team 1-3, Baechle Fall 2015
IUPUI-BAECHLE-F15S1G3
5 Leden
10 handleidingen geschreven
1Gids Commentaar
Very good instructions.....but where do I buy the repkacement battery from?
fremontmyers - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 17
Altijd: 794
