Inleiding
Within this guide the user will learn and follow the steps to replace the internal speakers of the JBL Flip. A soldering iron will be used to unsolder some wired connections. To safely use the soldering iron please visit this desoldering guide Hoe moet je (de-)solderen?.
Wat je nodig hebt
On the end with the buttons, remove the end cap using the flat head screwdriver to get between the rubber lining and the plastic.
After the cap is removed, unscrew the two 3.3mm screws using a size 1 ph screw driver.
Remove last white back plate to expose the back of the speaker cover.
the metal cover looks upside down to me: holes for rubber legs and DC jack should not come on one side (like in the pictures above)
Take a soldering iron to the two solders, one for each cable.
Once the soldering has melted, remove each wire from the speaker.
6 andere personen hebben deze handleiding voltooid.
9 opmerkingen
I want JBL flip 2 charging commector board.
Where can i buy ??
Plz help me
Where do you buy the replacement speakers?
I have a problem with the bluetooth of my speaker goes off after 10 minutes of running I have checked with several smart and it always repeats that I can do
Where I can get schematic diagram and plans of this equipment
I want to buy 2pcs replacement speaker for my JBL flip bluetooth speaker. Ho can I buy .and from
I also want new replacement speaker,can you tell me from where you have brought
i need jbl flip 2 speaker, where can i buy for it?
I want to know what type of flex cable is used in button panel of JBL flip 1 speaker A type or B type
