Ga door naar hoofdinhoud
JBL Clip 4 Battery Replacement
Wat je nodig hebt
  1. JBL Clip 4 Battery Replacement, Front Grill: stap 1, afbeelding 1 van 1
    • Get a tool to pry the front grill off, ideally using one of the iFixit tools. This is required as the front grill is glued onto the device.
    Vraag FixBot
    Voeg opmerking toe
  2. JBL Clip 4 Battery Replacement: stap 2, afbeelding 1 van 1
    • Now you just need to pry it off using your chosen tool and it should come off easily leaving you with the front grill separated from the device. Your device should look like this after removing the front grill.
    Vraag FixBot
    Voeg opmerking toe
  3. JBL Clip 4 Battery Replacement, Back Housing: stap 3, afbeelding 1 van 1
    • First, you must unscrew the 5 Phillip head screws (6mm) around the edge of the device.
    Vraag FixBot
    Voeg opmerking toe
  4. JBL Clip 4 Battery Replacement: stap 4, afbeelding 1 van 1
    • Now with the unscrewed front and back housing, you should see some cables that connect between the two. Simply unplug these cables and the back housing will come apart from the front.
    Vraag FixBot
    Voeg opmerking toe
  5. JBL Clip 4 Battery Replacement, Battery: stap 5, afbeelding 1 van 1
    • The battery connects into the motherboard, and it is inside the black box shaped part that has a cable connecting into the motherboard. You must disconnect the cable connecting the battery to the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  6. JBL Clip 4 Battery Replacement: stap 6, afbeelding 1 van 1
    • Now all you need to do is pull the battery out of the case its in and you have successfully disconnected the battery from the device.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Trey Adao
593 Reputatie
6 handleidingen geschreven
UMass Dartmouth, Team 3-4, Shaddix Spring 2026 Lid van UMass Dartmouth, Team 3-4, Shaddix Spring 2026
UMASSD-SHADDIX-S26S3G4
4 Leden
7 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 67
Altijd: 150
