Ga door naar hoofdinhoud
Intel NUC11TNKi5 CPU Fan Replacement
Wat je nodig hebt
  1. Intel NUC11TNKi5 CPU Fan Replacement, Remove back-plate: stap 1, afbeelding 1 van 1
    • Unscrew 4 screws located in corners of back-plate.
    • Remove the back-plate.
  2. Intel NUC11TNKi5 CPU Fan Replacement, Remove NVME module: stap 2, afbeelding 1 van 1
    • Unscrew the screw holding the NVME module.
    • Remove the NVME module, so there is an access to WiFi module.
  3. Intel NUC11TNKi5 CPU Fan Replacement, Unplug wires: stap 3, afbeelding 1 van 1
    • Unplug WiFi antenna pigtails. Lift them carefully.
    • Unplug the RTC/CMOS battery header. Be aware, that BIOS settings will be erased immediately and need to be restored manually, once NUC is power on again.
  4. Intel NUC11TNKi5 CPU Fan Replacement, Unscrew board screw: stap 4, afbeelding 1 van 1
    • Unscrew 2 board screws.
  5. Intel NUC11TNKi5 CPU Fan Replacement, Remove top cover: stap 5, afbeelding 1 van 1
    • Insert spudger tool inside the top cover opening area and lift the top cover and remove it.
  6. Intel NUC11TNKi5 CPU Fan Replacement: stap 6, afbeelding 1 van 1
    • Unscrew 6 screws from the top.
  7. Intel NUC11TNKi5 CPU Fan Replacement, Remove motherboard: stap 7, afbeelding 1 van 2 Intel NUC11TNKi5 CPU Fan Replacement, Remove motherboard: stap 7, afbeelding 2 van 2
    • Now, the motherboard can be removed by pulling the B-Key SATA screw lock.
  8. Intel NUC11TNKi5 CPU Fan Replacement, Remove the fan: stap 8, afbeelding 1 van 1
    • Unscrew 2 screws holding the fan.
    • Unplug wires from the motherboard.
    • Remove the fan.
  9. Intel NUC11TNKi5 CPU Fan Replacement, Remove the fan passive block: stap 9, afbeelding 1 van 2 Intel NUC11TNKi5 CPU Fan Replacement, Remove the fan passive block: stap 9, afbeelding 2 van 2
    • Unscrew 4 screws holding the fan passive block.
    • Remove the passive block. Be aware there is a thermal paste below.
  10. Intel NUC11TNKi5 CPU Fan Replacement, Clean old thermal paste: stap 10, afbeelding 1 van 3 Intel NUC11TNKi5 CPU Fan Replacement, Clean old thermal paste: stap 10, afbeelding 2 van 3 Intel NUC11TNKi5 CPU Fan Replacement, Clean old thermal paste: stap 10, afbeelding 3 van 3
    • Apply isopropyl alcohol (at least 90% purity) to cotton swabs.
    • Remove the old thermal paste form chips by using cotton swabs. Repeat cleaning until all paste is removed.
    • Remove the old thermal paste form passive block by using cotton swabs. Repeat cleaning until all paste is removed.
  11. Intel NUC11TNKi5 CPU Fan Replacement, Apply new thermal paste: stap 11, afbeelding 1 van 1
    • Apply new thermal paste on marked chips. Use small amount of paste and spread it with a firm paper. Do not apply any thermal paste on passive block.
  12. Intel NUC11TNKi5 CPU Fan Replacement, Put back the fan passive block: stap 12, afbeelding 1 van 1
    • Carefully, put back the passive block.
    • Screw 4 screws.
  13. Intel NUC11TNKi5 CPU Fan Replacement, Put back the fan: stap 13, afbeelding 1 van 1
    • Put back the fan.
    • Screw 2 screws.
    • Plug fan wires to the motherboard.
    • Apply electrical tape on fan, so it's firmly attached to the fan as well as to the passive block.
  14. Intel NUC11TNKi5 CPU Fan Replacement, Reassemble NUC: stap 14, afbeelding 1 van 1
    • To reassemble your NUC, follow disassembling instructions in reverse order.
    • When you first run the NUC, the BIOS settings and time settings have gone because battery was unplugged. Therefore, enter the BIOS and save the settings you would like to use. Don't forget to check the fan speed and its settings!
Conclusie
Één andere persoon heeft deze handleiding voltooid.
vookimedlo
259 Reputatie
1 Handleiding geschreven
Één opmerking
Pretty sure not all of those screws need to be removed from the top, but there doesn't seem to be any harm either. I also don't think the RTC power needed to be disconnected?
Is there a trick to getting those antenna cables back in? They were the most annoying part of reassembly by far.
Minic - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 38
Afgelopen 30 dagen: 154
Altijd: 457
