Ga door naar hoofdinhoud
Insignia Flex 8 Battery Replacement
Wat je nodig hebt
    1. Insignia Flex 8 Battery Replacement, Battery: stap 1, afbeelding 1 van 1
      • Make sure the power is off to avoid injury in the following steps.
      • Position the tablet so that the screen is face down.
      • The power button is located in the upper left hand corner.
      • Hold the power button for three seconds until the tablet powers down.
      Vraag FixBot
      Voeg opmerking toe
    2. Insignia Flex 8 Battery Replacement: stap 2, afbeelding 1 van 2 Insignia Flex 8 Battery Replacement: stap 2, afbeelding 2 van 2
      • Remove the back casing by sliding a credit card or a similarly thin but firm object in between the casing and the screen.
      • Run this object around the perimeter of the tablet until there is separation between the casing and the screen.
      • Remove the back casing and set aside.
      Vraag FixBot
      Voeg opmerking toe
    3. Insignia Flex 8 Battery Replacement: stap 3, afbeelding 1 van 1
      • Peel back the tape from battery and case.
      Vraag FixBot
      Voeg opmerking toe
    4. Insignia Flex 8 Battery Replacement: stap 4, afbeelding 1 van 1
      • Slide the spudger beneath battery to pry away it away from the case. Work around the battery, prying up all edges to remove from glue.
      • Do not puncture or bend battery. This could cause battery to leak acid.
      Vraag FixBot
      Voeg opmerking toe
    5. Insignia Flex 8 Battery Replacement: stap 5, afbeelding 1 van 1
      • Desolder the black, yellow and red connections from circuit board. Desoldering Help
      • Keep the soldering tool away from other components on the circuit board.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
4 andere personen hebben deze handleiding voltooid.
Tyler Tyrrell
890 Reputatie
4 handleidingen geschreven
Colorado Springs, Team 5-5, Panko Spring 2015 Lid van Colorado Springs, Team 5-5, Panko Spring 2015
UCCS-PANKO-S15S5G5
3 Leden
12 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 31
Altijd: 9,430
