Ga door naar hoofdinhoud
Huawei P20 Pro Home Button and Fingerprint Sensor Replacement
Wat je nodig hebt
  1. Huawei P20 Pro Home Button and Fingerprint Sensor Replacement, Rear Glass Replacement: stap 1, afbeelding 1 van 1
    • Switch off your phone.
    • Use an iOpener to loosen the adhesive beneath the rear glass. Apply the iOpener for at least two minutes. You might want to repeat this step several times during the back cover removal.
    • The adhesive of the Huawei P20 Pro is of moderate strength, however a hair dryer, heat gun, or hot plate may also be used if you aren't able to open the device with the iOpener. Be careful not to overheat the phone—the OLED display and internal battery are both susceptible to heat damage.
  2. Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: stap 2, afbeelding 1 van 3 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: stap 2, afbeelding 2 van 3 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: stap 2, afbeelding 3 van 3
    • If the phone's rear glass is cracked, a suction cup may not stick very well. Try lifting it with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed.
    • Press a suction cup onto the rear glass close to the bottom edge of the phone.
    • Lift the bottom edge with the suction cup, opening a slight gap between the rear glass and the frame.
    • Insert an opening pick in the gap and slide it to the bottom right corner. Leave it there to prevent the adhesive from resealing.
  3. Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: stap 3, afbeelding 1 van 2 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: stap 3, afbeelding 2 van 2
    • Insert a second opening pick and slide it to the bottom left corner. Leave it there to prevent the adhesive from resealing.
  4. Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: stap 4, afbeelding 1 van 3 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: stap 4, afbeelding 2 van 3 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: stap 4, afbeelding 3 van 3
    • Insert a third opening pick at the bottom left corner.
    • Slide the tip of the opening pick along the left edge of the phone to cut the adhesive.
    • Leave the opening pick in the top left corner of the phone to prevent the adhesive from resealing.
  5. Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: stap 5, afbeelding 1 van 2 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: stap 5, afbeelding 2 van 2
    • In case you're having trouble to cut the adhesive, reapply the iOpener for another minute to loosen it.
    • Insert a fourth opening pick at the top left corner of the phone.
    • Slide the opening pick along the upper edge of the phone to cut the adhesive beneath the rear glass and leave it in the top right corner.
  6. Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: stap 6, afbeelding 1 van 3 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: stap 6, afbeelding 2 van 3 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: stap 6, afbeelding 3 van 3
    • Insert a fifth opening pick at the top right corner of the rear glass.
    • Slide the opening pick along the right edge of the phone to cut the remaining adhesive.
    • Don't open the phone all the way yet. The proximity sensor flex cable is still connected to the motherboard.
  7. Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: stap 7, afbeelding 1 van 3 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: stap 7, afbeelding 2 van 3 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: stap 7, afbeelding 3 van 3
    • Carefully lift the rear glass until you can reach the connector of the proximity sensor flex cable next to the rear camera assembly.
  8. Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: stap 8, afbeelding 1 van 2 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: stap 8, afbeelding 2 van 2
    • Use the flat end of a spudger to pry up and disconnect the proximity sensor flex cable.
  9. Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: stap 9, afbeelding 1 van 2 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: stap 9, afbeelding 2 van 2
    • Remove the rear glass.
    • Before installing fresh adhesive and reassembly, remove any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
  10. Huawei P20 Pro Home Button and Fingerprint Sensor Replacement, Motherboard Cover and NFC: stap 10, afbeelding 1 van 1
    • Remove the nine Phillips #00 screws (3.4 mm length).
  11. Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: stap 11, afbeelding 1 van 3 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: stap 11, afbeelding 2 van 3 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: stap 11, afbeelding 3 van 3
    • Insert an opening pick under the left side of the motherboard cover that includes the NFC.
    • Slide the opening pick towards the top left corner of the phone and twist it to pry the cover out of its plastic clamps.
  12. Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: stap 12, afbeelding 1 van 2 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: stap 12, afbeelding 2 van 2
    • Repeat the previous process on the right side and twist the opening pick to pry up the motherboard cover.
  13. Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: stap 13, afbeelding 1 van 1
    • Remove the motherboard cover.
  14. Huawei P20 Pro Home Button and Fingerprint Sensor Replacement, Battery Disconnect: stap 14, afbeelding 1 van 2 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement, Battery Disconnect: stap 14, afbeelding 2 van 2
    • Use the flat end of a spudger to pry up and disconnect the battery flex cable.
  15. Huawei P20 Pro Home Button and Fingerprint Sensor Replacement, Interconnect Cable with Charging Port: stap 15, afbeelding 1 van 1
    • Remove the five Phillips #00 screws (3.4 mm length).
  16. Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: stap 16, afbeelding 1 van 3 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: stap 16, afbeelding 2 van 3 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: stap 16, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • Use a pair of tweezers to disconnect the antenna cable.
    • Use a pair of tweezers to pull the antenna cable out of its routing.
  17. Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: stap 17, afbeelding 1 van 3 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: stap 17, afbeelding 2 van 3 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: stap 17, afbeelding 3 van 3
    • Slide an opening pick under the left side of the daughterboard cover and start to pry it up until you can get a good grip.
    • Remove the daughterboard cover.
  18. Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: stap 18, afbeelding 1 van 1
    • Remove the two Phillips #00 screws (3.4 mm length) on both sides of the USB C port.
  19. Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: stap 19, afbeelding 1 van 2 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: stap 19, afbeelding 2 van 2
    • Use the flat end of a spudger to pry up and disconnect the upper end of the interconnect and charging port flex cable from the motherboard.
  20. Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: stap 20, afbeelding 1 van 3 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: stap 20, afbeelding 2 van 3 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: stap 20, afbeelding 3 van 3
    • Use the flat end of a spudger to pry up and disconnect the bottom end of the interconnect and charging port flex cable from the daughterboard.
    • Use a pair of tweezers to move the antenna cable out of the way.
  21. Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: stap 21, afbeelding 1 van 3 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: stap 21, afbeelding 2 van 3 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: stap 21, afbeelding 3 van 3
    • Use a pair of tweezers to pull the charging port out of its recess.
    • Remove the interconnect cable including the charging port.
  22. Huawei P20 Pro Home Button and Fingerprint Sensor Replacement, Battery: stap 22, afbeelding 1 van 3 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement, Battery: stap 22, afbeelding 2 van 3 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement, Battery: stap 22, afbeelding 3 van 3
    • Use an iOpener to loosen the adhesive beneath the battery. Apply the iOpener on the display for at least two minutes.
    • In the following step, only apply the spudger in the areas marked in red, which is where the battery adhesive is located.
    • Avoid the orange area where the display flex cable is running.
  23. Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: stap 23, afbeelding 1 van 3 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: stap 23, afbeelding 2 van 3 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: stap 23, afbeelding 3 van 3
    • In case you have trouble to pry up the battery the adhesive may not be loose enough. You can apply some isopropyl alcohol under each corner of the battery and allow it to penetrate for about two minutes to help weaken the adhesive.
    • Try your best not to deform the battery during the following removal process. Soft-shell lithium-ion batteries can leak dangerous chemicals, catch fire, or even explode if damaged. Do not use excessive force or pry at the battery with metal tools.
    • Insert the flat end of a spudger at the top left corner of the battery and start to pry it up.
    • Work your way down the left side of the battery and loosen the adhesive with the spudger.
  24. Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: stap 24, afbeelding 1 van 3 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: stap 24, afbeelding 2 van 3 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: stap 24, afbeelding 3 van 3
    • Insert the spudger at the top right corner of the battery and start to pry it up.
    • Work your way down to the bottom end of the battery to loosen all the adhesive.
  25. Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: stap 25, afbeelding 1 van 2 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: stap 25, afbeelding 2 van 2
    • Remove the battery.
    • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard. Replace it with a new battery.
    • Before installing a new battery remove any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
    • Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the phone at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place for 5-10 seconds.
  26. Huawei P20 Pro Home Button and Fingerprint Sensor Replacement, Screen: stap 26, afbeelding 1 van 2 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement, Screen: stap 26, afbeelding 2 van 2
    • Use the flat end of a spudger to pry up and disconnect the display flex cable at the bottom left of the motherboard.
  27. Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: stap 27, afbeelding 1 van 1
    • Prepare an iOpener and apply it to the display for at least two minutes to loosen the adhesive beneath.
    • You may need to reheat and reapply the iOpener several times to get the phone warm enough on all sides. Follow the iOpener instructions to avoid overheating.
    • If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the display until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
  28. Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: stap 28, afbeelding 1 van 3 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: stap 28, afbeelding 2 van 3 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: stap 28, afbeelding 3 van 3
    • Once the screen is warm to the touch, apply a suction cup to the upper edge of the phone.
    • Pull the suction cup upwards and insert an opening pick in the gap between the display glass and the plastic bezel. Start to cut the adhesive by sliding the opening pick to the top left corner.
    • Make sure you get in the right gap between the display and the plastic bezel. Do not pry between the bezel and the midframe.
  29. Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: stap 29, afbeelding 1 van 2 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: stap 29, afbeelding 2 van 2
    • Insert a second opening pick and slide it to the top right corner of the phone.
    • Leave the picks in their places to prevent the adhesive from resealing.
  30. Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: stap 30, afbeelding 1 van 3 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: stap 30, afbeelding 2 van 3 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: stap 30, afbeelding 3 van 3
    • Insert a third opening pick at the top right corner of the phone.
    • Slide the opening pick down to the bottom right corner to cut all the adhesive. Leave it at the bottom right corner to prevent the adhesive from resealing.
    • If cutting becomes too difficult, reheat and reapply the iOpener.
  31. Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: stap 31, afbeelding 1 van 2 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: stap 31, afbeelding 2 van 2
    • Insert a fourth opening pick at the bottom right corner.
    • Only slide the tip of the opening pick along the bottom edge of the phone to not damage the home button.
    • Leave the opening pick in the bottom left corner to prevent the adhesive from resealing.
  32. Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: stap 32, afbeelding 1 van 2 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: stap 32, afbeelding 2 van 2
    • Insert a fifth opening pick and slide it along the left edge of the phone to cut the remaining adhesive.
    • Try not to remove the display all the way yet, the display cable is still threaded through the frame and adhered on the opposite side.
  33. Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: stap 33, afbeelding 1 van 2 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: stap 33, afbeelding 2 van 2
    • Use a pair of tweezers to peel the display flex cable free from the frame.
    • Thread the display flex cable through the gap in the frame and remove the display.
  34. Huawei P20 Pro Home Button and Fingerprint Sensor Replacement, Home button including the fingerprint sensor: stap 34, afbeelding 1 van 2 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement, Home button including the fingerprint sensor: stap 34, afbeelding 2 van 2
    • Use an opening pick to open the black flap of the home button ZIF connector.
  35. Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: stap 35, afbeelding 1 van 2 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: stap 35, afbeelding 2 van 2
    • Use a pair of tweezers to gently pull the home button flex cable out of its ZIF connector.
  36. Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: stap 36, afbeelding 1 van 1
  37. Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: stap 37, afbeelding 1 van 3 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: stap 37, afbeelding 2 van 3 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: stap 37, afbeelding 3 van 3
    • Apply a spudger to the backside of the home button and push it out towards the front until it comes off the screen.
    • Carefully grab the home button and thread its flex cable through the gap in the screen.
    • Remove the home button.
    • Before installing a new display, it's important to remove all traces of the old adhesive from the frame, and clean the glued areas with isopropyl alcohol (>90%) and a lint-free cloth.
Conclusie
The best way to re-apply the screen is with a sheet of custom-cut double-sided tape. Remove any old ahesive and apply the new tape to the back of the screen, then carefully feed the display cable through the frame. Align the screen and press it into place.
If possible, turn on your phone and test your repair before installing new adhesive and resealing the phone.
5 andere personen hebben deze handleiding voltooid.
Dominik Schnabelrauch
228.969 Reputatie
682 handleidingen geschreven
iFixit Lid van iFixit
Staff
118 Leden
19.413 handleidingen geschreven
11 opmerkingen
Hello, is p20 fingerprint sensor same as p20 pro and can u switch them betwin models? Thanks for answer.
michi125125 - Antwoord
Is it really needed to dissemble all the phone? The more I look at tutorial, the more it seems you can just unglue the screen (while it's still attached to the phone) and remove the fingerprint scanner. I'm I wrong?
Christo Bd - Antwoord
Hi Christo,
the display cable of the Huawei P20 Pro is held in place by adhesive underneath the battery. Not removing the battery and loosening the adhesive underneath the cable will result in damage to the display and/or display cable when trying to lift the screen. At the same time the glued cable will hold the display in place and it won’t be possible to lift the display high enough to open the ZIF connector of the fingerprint without causing critical tension to the cable. However it can be possible to do it the way you were mentioning but this will require some experience with smartphone repairs and a good amount of instinctive feeling.
Dominik Schnabelrauch -
Leider ist mit beim Herausdrücken des Sensors der Metallrahmen mit herausgefallen. Diesen bekomme ich jetzt nicht mehr fest. Was mache ich denn jetzt? :(
Thorsten - Antwoord
Hi Thorsten, Ich vermute mal, dass der Metallrahmen auch mit Klebstoff von hinten am Display befestigt ist. Wenn du sagst, dass du ihn nicht mehr fest bekommst, liegt es daran dass es nicht mehr klebt oder der Klebstoff verformt ist. Falls noch gut in FOrm kann es schon genügen ihn warm zu machen und wieder ran zu drücken. Ansonsten muss man womöglich den alten Klebstoff entfernen, die Stelle reinigen und neuen Klebstoff anbringen. Zum Reinigen benutzt du am besten Isopropanol (>90%). Als Klebstoff bietet sich dieses doppelseitiges Klebeband an (könnte evtl aber auch zu schwach sein zwecks des Drucks auf den Button) oder ein Klebstoff wie der E6000. Allerdings ist es schwer zu sagen wie die Stoffe sich mit dem Display vertragen. Auf jeden Fall viel Erfolg mit der Reparatur.
Tobias Isakeit -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 19
Afgelopen 30 dagen: 109
Altijd: 33,144
