Inleiding
Use this guide to replace the battery in your Huawei P10 smartphone.
Wat je nodig hebt
Switch off your phone.
Remove the two Pentalobe P2 screws at the bottom.
Remove the SIM card tray.
Peel out the adhesive strip which is placed beneath the battery by steadily pulling at the tab in a flat angle.
Use an iOpener to loosen the remaining adhesive.
To reassemble your device, follow these instructions in reverse order. When reassembling your phone apply new adhesive where it is necessary.
76 andere personen hebben deze handleiding voltooid.
16 opmerkingen
Thanks for posting this this give me new ideas.
Facile comme bonjour. Les outils que j'avais reçu avec la batterie étaient de piètre qualité, j'ai donc utilisé des mini-spatules utilisées pour lisser les joints en silicone, c'est pile la consistance voulue pour décoller le dos et la batterie, ni trop ferme ni trop souple.
Easy fix, thanks a lot.
Eccellente guida peccato che una volta montata la nuova batteria in cellulare si sente che si accende la il display rimane buio, controllato connessioni ma sono tutte ok e display sempre spento, cosa può essere?
Adriano
