Ga door naar hoofdinhoud
Huawei Mate 8 Display Replacement
Wat je nodig hebt
  1. Huawei Mate 8 Display Replacement, Back Cover: stap 1, afbeelding 1 van 2 Huawei Mate 8 Display Replacement, Back Cover: stap 1, afbeelding 2 van 2
    • Switch off your phone and remove the SIM card tray.
  2. Huawei Mate 8 Display Replacement: stap 2, afbeelding 1 van 1
    • Remove the Torx T2 screws from the bottom of the phone
  3. Huawei Mate 8 Display Replacement: stap 3, afbeelding 1 van 2 Huawei Mate 8 Display Replacement: stap 3, afbeelding 2 van 2
    • Use an iSclack or a suction handle in the bottom area of your phone to separate the display unit from the rear panel.
  4. Huawei Mate 8 Display Replacement: stap 4, afbeelding 1 van 3 Huawei Mate 8 Display Replacement: stap 4, afbeelding 2 van 3 Huawei Mate 8 Display Replacement: stap 4, afbeelding 3 van 3
    • Use an opening pick to fully separate the clips, releasing the phone.
    • Do not fully remove the rear case. The fingerprint sensor cable is still connected to the back cover.
    • Open the phone like a book from the SIM tray side.
    • Use a spudger, to disconnect the fingerprint sensor cable.
  5. Huawei Mate 8 Display Replacement, Daughterboard interconnect cable: stap 5, afbeelding 1 van 3 Huawei Mate 8 Display Replacement, Daughterboard interconnect cable: stap 5, afbeelding 2 van 3 Huawei Mate 8 Display Replacement, Daughterboard interconnect cable: stap 5, afbeelding 3 van 3
    • Remove the liquid indicator sticker.
    • Remove the Phillips #00 screw that holds down the metal shield.
    • The metal shield is tightly held in place. If you try to remove it without holding it down on one side, it'll break easily.
    • Use a spudger to remove the metal shield.
  6. Huawei Mate 8 Display Replacement: stap 6, afbeelding 1 van 3 Huawei Mate 8 Display Replacement: stap 6, afbeelding 2 van 3 Huawei Mate 8 Display Replacement: stap 6, afbeelding 3 van 3
    • Use the flat end of a spudger to disconnect the display, daughterboard interconnect, and battery cables.
  7. Huawei Mate 8 Display Replacement: stap 7, afbeelding 1 van 1
    • Remove the Phillips #00 screw that holds down the interconnect cable bracket.
  8. Huawei Mate 8 Display Replacement: stap 8, afbeelding 1 van 2 Huawei Mate 8 Display Replacement: stap 8, afbeelding 2 van 2
    • Lift the coaxial connector off of its socket to allow access to the daughterboard interconnect cable bracket.
    • Remove the bracket.
  9. Huawei Mate 8 Display Replacement: stap 9, afbeelding 1 van 1
    • Use a spudger to disconnect the interconnect cable.
    • Remove the interconnect cable.
  10. Huawei Mate 8 Display Replacement, Battery: stap 10, afbeelding 1 van 1
    • The battery is glued in place with two adhesive strips. One with a pull tab and one without.
    • Get a good grip on the pull tab near the power button and peel out the adhesive strip by steadily pulling at the tab in a flat angle.
    • If the adhesive strip rips, grab and twist it around the tweezer tips a couple of times and then continue.
  11. Huawei Mate 8 Display Replacement: stap 11, afbeelding 1 van 3 Huawei Mate 8 Display Replacement: stap 11, afbeelding 2 van 3 Huawei Mate 8 Display Replacement: stap 11, afbeelding 3 van 3
    • Do not bend or puncture the battery, damage to the cell can cause battery fires.
    • Heat an iOpener and place it on the phone for about a minute to loosen the remaining adhesive.
    • Carefully insert the flat end of a spudger to separate any remaining adhesive at the top of the battery.
  12. Huawei Mate 8 Display Replacement: stap 12, afbeelding 1 van 2 Huawei Mate 8 Display Replacement: stap 12, afbeelding 2 van 2
    • Lift the top end of the battery to pull the battery off of the remaining adhesive strip.
    • When reassembling your phone, apply stretch release adhesive strips, double sided adhesive tape, or pre-cut adhesive to secure the new battery.
    • Never reinstall a battery that has been bent or damaged during removal.
  13. Huawei Mate 8 Display Replacement, Display: stap 13, afbeelding 1 van 1
    • Remove the four Phillips #00 screws holding the daughterboard and loudspeaker to the phone.
  14. Huawei Mate 8 Display Replacement: stap 14, afbeelding 1 van 2 Huawei Mate 8 Display Replacement: stap 14, afbeelding 2 van 2
    • Use the flat end of a spudger to disconnect the loudspeaker connector cable.
    • Use the tip of a spudger to lift the daughterboard from the phone.
  15. Huawei Mate 8 Display Replacement: stap 15, afbeelding 1 van 2 Huawei Mate 8 Display Replacement: stap 15, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Insert the flat end of a spudger under the loudspeaker at the gap on the left side.
    • Work the spudger under the loudspeaker to seperate it from the adhesive and remove the loudspeaker.
    • Use tweezers to take the vibration unit out of its housing.
  16. Huawei Mate 8 Display Replacement: stap 16, afbeelding 1 van 1
    • Remove the eight Phillips #00 screws securing the motherboard to the phone.
  17. Huawei Mate 8 Display Replacement: stap 17, afbeelding 1 van 2 Huawei Mate 8 Display Replacement: stap 17, afbeelding 2 van 2
    • Remove the bracket from the rear camera flex cable.
    • Use tweezers to disconnect the antenna cable.
  18. Huawei Mate 8 Display Replacement: stap 18, afbeelding 1 van 3 Huawei Mate 8 Display Replacement: stap 18, afbeelding 2 van 3 Huawei Mate 8 Display Replacement: stap 18, afbeelding 3 van 3
    • Use the flat end of a spudger to disconnect the volume and power flex cable on the bottom left side of the mainboard.
    • Work the flat end of a spudger under the top right side of the mainboard to pry it out.
    • Remove the mainboard.
  19. Huawei Mate 8 Display Replacement: stap 19, afbeelding 1 van 2 Huawei Mate 8 Display Replacement: stap 19, afbeelding 2 van 2
    • Remove the antenna interconnect cable.
    • Remove the power and volume switch assembly.
  20. Huawei Mate 8 Display Replacement: stap 20, afbeelding 1 van 3 Huawei Mate 8 Display Replacement: stap 20, afbeelding 2 van 3 Huawei Mate 8 Display Replacement: stap 20, afbeelding 3 van 3
    • Use tweezers to remove the earpiece speaker.
    • Remove the red rubber gasket.
    • Remove the ambient light and proximity sensor.
Conclusie
9 andere personen hebben deze handleiding voltooid.
Dominik Schnabelrauch
246.775 Reputatie
682 handleidingen geschreven
iFixit Lid van iFixit
Staff
123 Leden
23.626 handleidingen geschreven
1Gids Commentaar
Tidy. Really tidy like.
Marc Vestabule - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 50
Altijd: 6,522
