Inleiding
Use this guide to replace the battery in your Huawei Mate 8 smartphone.
Wat je nodig hebt
Remove the liquid indicator sticker.
Remove the Phillips #00 screw that holds down the metal shield.
Use a spudger to remove the metal shield.
Get a good grip on the pull tab near the power button and peel out the adhesive strip by steadily pulling at the tab in a flat angle.
Heat an iOpener and place it on the phone for about a minute to loosen the remaining adhesive.
Carefully insert the flat end of a spudger to separate any remaining adhesive at the top of the battery.
To reassemble your device, follow these instructions in reverse order. When reassembling your phone apply new adhesive where it is necessary.
17 andere personen hebben deze handleiding voltooid.
7 opmerkingen
great guide changed my battery in under 30 min thank you @schnabel
Hi George,
nice to hear and i hope your phone works well!
Thanks for the great guide! It took some effort to open the phone and to remove the old glue. Also with my old eyes (60 years) I could hardly see the tiny screws an connectors, even with my reading glasses on so it took me 2 1/2 hours to finish, but succeeded after all! Never did this before, so it is doable without experience, but you do need the tools. A looking glass would be helpfull too :)
