Ga door naar hoofdinhoud
Huawei M750 Camera Replacement
Wat je nodig hebt
  1. Huawei M750 Camera Replacement, Battery: stap 1, afbeelding 1 van 1
    • Depress the top of the battery cover, and pull downwards towards the base of the phone.
    Vraag FixBot
    Voeg opmerking toe
  2. Huawei M750 Camera Replacement: stap 2, afbeelding 1 van 1
    • Remove the battery by levering the battery out, using the cut just below the camera.
    Vraag FixBot
    Voeg opmerking toe
  3. Huawei M750 Camera Replacement, Back Panel: stap 3, afbeelding 1 van 1
    • Use the opening tool to start prying the camera and speaker cover, starting from the battery side.
    • Work the opening tool around the border of the camera and speaker cover, until it comes loose.
    Vraag FixBot
    Voeg opmerking toe
  4. Huawei M750 Camera Replacement: stap 4, afbeelding 1 van 2 Huawei M750 Camera Replacement: stap 4, afbeelding 2 van 2
    • Using the T5 Torx screwdriver, remove the six 6mm screws.
    Vraag FixBot
    Voeg opmerking toe
  5. Huawei M750 Camera Replacement: stap 5, afbeelding 1 van 2 Huawei M750 Camera Replacement: stap 5, afbeelding 2 van 2
    • Using the opening tool, pry the back panel from the front panel.
    • Work your way around the phone until the panels separate evenly.
    • This step may require a substantial amount of leverage.
    Vraag FixBot
    Voeg opmerking toe
  6. Huawei M750 Camera Replacement, Camera: stap 6, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • The camera's connection to the motherboard is shown here.
    • Using the tweezers, disconnect the port, shown here in the picture.
    Vraag FixBot
    Voeg opmerking toe
  7. Huawei M750 Camera Replacement: stap 7, afbeelding 1 van 1
    • Using the tweezers, carefully remove the lens and lens casing.
    • It should be held in by a simple tight fit. The front panel is what keeps the lens secured.
    • Do not touch the camera lens, or the digital camera component, if possible. This will prevent scratching, or damage.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 27
Altijd: 539
