Ga door naar hoofdinhoud
Huawei Honor 9 Rear Glass Removal
Wat je nodig hebt
  1. Huawei Honor 9 Rear Glass Removal, Remove the Rear Glass: stap 1, afbeelding 1 van 1
    • Switch off your phone.
    • Heat an iOpener and apply it to the back of the phone for around two minutes. This will help soften the adhesive securing the rear glass.
    • You might need to reheat and reapply the iOpener several times during the rear glass removal.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. Huawei Honor 9 Rear Glass Removal: stap 2, afbeelding 1 van 2 Huawei Honor 9 Rear Glass Removal: stap 2, afbeelding 2 van 2
    • Secure a suction handle to the lower edge of the rear glass, as close to the edge as possible.
    • If the phone's rear glass is cracked, the suction cup may not stick. Try lifting it with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed.
    • Lift the rear glass with the suction cup to create a gap between the glass and the frame.
    • Insert an opening pick into the gap.
    • Don't attempt to insert a pick between the back glass and the frame before creating a gap. The glass is covered with foil from the inside, and by not creating a gap, you risk inserting the pick between the glass and the foil instead, which would permanently damage the foil and ruin the solid color of the back panel.
    • If you have trouble, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
  3. Huawei Honor 9 Rear Glass Removal: stap 3, afbeelding 1 van 3 Huawei Honor 9 Rear Glass Removal: stap 3, afbeelding 2 van 3 Huawei Honor 9 Rear Glass Removal: stap 3, afbeelding 3 van 3
    • Slide the opening pick to the bottom right corner.
    • Insert a second opening pick and slide it to the bottom left corner.
    • Leave the opening picks in place to prevent the adhesive from resealing.
  4. Huawei Honor 9 Rear Glass Removal: stap 4, afbeelding 1 van 3 Huawei Honor 9 Rear Glass Removal: stap 4, afbeelding 2 van 3 Huawei Honor 9 Rear Glass Removal: stap 4, afbeelding 3 van 3
    • Insert a third opening pick at the bottom left corner.
    • Start to slide the tip of the opening pick from the bottom left corner along the side of the Huawei Honor 9 to cut the adhesive.
    • Leave the opening pick in its place at the top left corner to prevent the adhesive from resealing.
  5. Huawei Honor 9 Rear Glass Removal: stap 5, afbeelding 1 van 2 Huawei Honor 9 Rear Glass Removal: stap 5, afbeelding 2 van 2
    • If the adhesive gets hard to cut it is likely too cold. Use your iOpener to reheat it.
    • Insert a fourth opening pick under the top left corner of the rear glass.
    • Slide the opening pick along the top edge of the phone to cut the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  6. Huawei Honor 9 Rear Glass Removal: stap 6, afbeelding 1 van 2 Huawei Honor 9 Rear Glass Removal: stap 6, afbeelding 2 van 2
    • Insert a fifth opening pick at the top right corner of the phone.
    • Slide the opening pick along the right side to cut the remaining adhesive.
  7. Huawei Honor 9 Rear Glass Removal: stap 7, afbeelding 1 van 2 Huawei Honor 9 Rear Glass Removal: stap 7, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Tesa 61395 Tape
    $5.99
    • Carefully lift the rear glass and remove it.
    • Secure the new rear glass with pre-cut adhesive or double-sided adhesive tape.
    • After installing the rear glass, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond, such as by placing it under a stack of heavy books.
Conclusie
Dominik Schnabelrauch
230.775 Reputatie
682 handleidingen geschreven
iFixit Lid van iFixit
Staff
118 Leden
19.636 handleidingen geschreven
2Gids Commentaar
Bon tuto, mais la pièce de rechange n’est pas en vente… :( Comment puis-je me la procurer?
Roxane - Antwoord
yeah sooo
i did this in 2 minutes
without an iopener
you don’t need that
Dante - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 45
Altijd: 3,376
