Ga door naar hoofdinhoud
How to replace the Azpen A720 Wi-Fi Antenna
Wat je nodig hebt
    1. How to replace the Azpen A720 Wi-Fi Antenna, Back Cover: stap 1, afbeelding 1 van 2 How to replace the Azpen A720 Wi-Fi Antenna, Back Cover: stap 1, afbeelding 2 van 2
      • Use a Phillips #00 screwdriver to remove the two 4mm screws found on the top edge of the tablet near the power button.
      Vraag FixBot
      Voeg opmerking toe
    2. How to replace the Azpen A720 Wi-Fi Antenna: stap 2, afbeelding 1 van 3 How to replace the Azpen A720 Wi-Fi Antenna: stap 2, afbeelding 2 van 3 How to replace the Azpen A720 Wi-Fi Antenna: stap 2, afbeelding 3 van 3
      • Use the plastic opening tool to pry the white back from the silver frame. Start near the micro SD slot.
      • Slide the plastic opening tool around the perimeter of the casing until the back is disconnected.
      Vraag FixBot
      Voeg opmerking toe
    3. How to replace the Azpen A720 Wi-Fi Antenna: stap 3, afbeelding 1 van 1
      • Remove the rear casing.
      Vraag FixBot
      Voeg opmerking toe
    1. How to replace the Azpen A720 Wi-Fi Antenna, Wi-Fi Antenna: stap 4, afbeelding 1 van 1
      • Locate the gray cord attached to the motherboard and the battery. This is the wifi antenna.
      Vraag FixBot
      Voeg opmerking toe
    2. How to replace the Azpen A720 Wi-Fi Antenna: stap 5, afbeelding 1 van 2 How to replace the Azpen A720 Wi-Fi Antenna: stap 5, afbeelding 2 van 2
      • Locate the soldering connection between the wifi antenna and the motherboard.
      • Using a soldering iron, melt the soldering connection between the cord and the motherboard and disconnect the cord.
      • The soldering iron gets very hot, be careful not to touch the tip to avoid burns. Click here to learn how to solder.
      Vraag FixBot
      Voeg opmerking toe
    3. How to replace the Azpen A720 Wi-Fi Antenna: stap 6, afbeelding 1 van 2 How to replace the Azpen A720 Wi-Fi Antenna: stap 6, afbeelding 2 van 2
      • Locate the black sticker connecting the wifi antenna to the battery.
      • Peel the black sticker off of the battery to disconnect the wifi antenna.
      • Remove and replace the defective wire.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Anna
353 Reputatie
3 handleidingen geschreven
Michigan Tech, Team 1-3, Lauer Spring 2015 Lid van Michigan Tech, Team 1-3, Lauer Spring 2015
MTU-LAUER-S15S1G3
2 Leden
5 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 26
Altijd: 1,471
