Inleiding
Use this guide to open the Huawei Watch GT2e and remove the rear assembly.
Wat je nodig hebt
Turn off the watch:
Press and hold the top button for >3 sec.
Tap "Power off".
Push the small sliding nub on one of the watch band pins inwards toward the center of the watch band.
While holding the nub in, pull one side of the pin out of its recess on the watch housing, then the other side.
Remove the band.
Repeat this process to remove the second band.
Remove the four 3.5 mm-long T3 Torx screws on the back of the watch.
Place the point of a spudger in the small hole on the side of the rear case.
Use the spudger to push the rear case away from the housing to create a small gap. Use steady force to separate the two parts.
Flip the rear case assembly open towards the buttons to access the interconnect flex cable connector.
Gereedschap gebruikt in deze stap:Tweezers$3.99
Remove the 2.5 mm-long Phillips screw securing the interconnect cable bracket.
Use a pair of tweezers to slide the interconnect cable bracket down and left to unlatch it.
Remove the interconnect cable bracket.
Use the flat end of a spudger to pry up and unplug the interconnect cable.
Remove the rear case assembly.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answer Community for help.
