Ga door naar hoofdinhoud
How to Wash a Waterproof Jacket
Wat je nodig hebt
  1. How to Wash a Waterproof Jacket, Wipe away dirt and debris: stap 1, afbeelding 1 van 2 How to Wash a Waterproof Jacket, Wipe away dirt and debris: stap 1, afbeelding 2 van 2
    • Look over your jacket and wipe away dirt and debris.
    • For stubborn stains, spot clean using a mild soap or rubbing alcohol. See Spot Cleaning Technical Gear for more details.
  2. How to Wash a Waterproof Jacket, Prepare your jacket: stap 2, afbeelding 1 van 3 How to Wash a Waterproof Jacket, Prepare your jacket: stap 2, afbeelding 2 van 3 How to Wash a Waterproof Jacket, Prepare your jacket: stap 2, afbeelding 3 van 3
    • Zip up the main zipper.
    • Leave pockets unzipped so they can be cleaned inside.
    • Empty all pockets. Check for trash, treasures, or forgotten tissues.
    • Loosen drawstrings and drawcords.
    • Fasten any hook-and-loop closures in their most relaxed position to avoid snagging.
  3. How to Wash a Waterproof Jacket, Load the washing machine: stap 3, afbeelding 1 van 1
    • Place your jacket in the washing machine.
    • Add 1-3 jackets at a time. Avoid overfilling the drum—technical garments need room to move freely in the wash.
    • Ideally, use a front-loading washer.
    • Top-loaders usually have agitators, a rotating spindle that creates friction to clean your gear. Jackets can get caught in that spindle, leading to tangles, tears, or scratches.
    • If you don’t have a washing machine, hand-washing is a great alternative. You'll still need a dryer or iron to heat-set afterward!
  4. How to Wash a Waterproof Jacket, Add detergent: stap 4, afbeelding 1 van 1
    • Add technical gear soap or gentle biodegradable laundry detergent to the washing machine.
    • Patagonia recommends Storm Wash, which is specially formulated for technical outerwear and equipment.
    • For standard detergent, choose one that's liquid, biodegradable, and free of dyes. Look for labels like "organic" or "sensitive skin."
    • Avoid detergent containing fabric softeners, stain removers, perfumes, whiteners, or bleach.
  5. How to Wash a Waterproof Jacket, Set the washing machine: stap 5, afbeelding 1 van 2 How to Wash a Waterproof Jacket, Set the washing machine: stap 5, afbeelding 2 van 2
    • Set the load size to small or medium, depending on the number of garments you're washing.
    • Set the water temperature to cold or warm.
    • Set the wash cycle to normal or gentle/delicate/permanent press. If possible, add an extra rinse cycle to ensure all residues are removed.
    • Set the spin cycle to low.
    • Start the washing machine.
  6. How to Wash a Waterproof Jacket, Tumble Dry: stap 6, afbeelding 1 van 3 How to Wash a Waterproof Jacket, Tumble Dry: stap 6, afbeelding 2 van 3 How to Wash a Waterproof Jacket, Tumble Dry: stap 6, afbeelding 3 van 3
    • Hang the jacket up to drip dry first to remove excess water, then tumble dry on low heat for at least 30 minutes or until the jacket is fully dry.
    • Don't skip the dryer! Heat activates the durable water resistant (DWR) coating.
    • If you don’t have a dryer, you can use an iron to reactivate the DWR. Carefully follow the steps in How to Iron a Waterproof Jacket.
    • Your jacket is clean, dry, and ready for whatever the weather throws your way!
    • Get back out there!
Eindstreep
8 andere personen hebben deze handleiding voltooid.
Clara Redwood
2.544 Reputatie
18 handleidingen geschreven
Patagonia Lid van Patagonia
Community
17 Leden
168 handleidingen geschreven
7Gids Commentaar
I’m very happy after read this easy step of washing water proof jacket.Thanks for sharing this great post!!I bought water proof jacket from online store, and i got 60% off by using promo code; snow and rock promo codes.The jacket dries really fast and it’s 100% waterproof until i washed it.Color maintained very well, after it was washed.
Albert Daniel - Antwoord
The tips and suggestion was outstanding i try my husband jacket it was mess with factory work, i just buy my new washing machine from appliance connection with a reasonable prices appliances connection promo code and i get upto 40% discount on my first purchase you can also try.
Rachel - Antwoord
Is it ok to wash two or three waterproof jackets together in the same load? Thank you!
Sarah Geers - Antwoord
White lining is flaking off ALL my Patagonia waterproof jackets - delaminated white liner. Refund the thousands of dollars I spent on this garbage?
choffman - Antwoord
They absolutely will replace it or give you store credit.
Nathan Keirn -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 11
Afgelopen 7 dagen: 70
Afgelopen 30 dagen: 290
Altijd: 58,027
